Member # 13820
Soild tie rod Questions
I am contemplating building a tie rod and drag link from solid steel round stock. Manny are running this type of set up and I am basicly looking for any cons against soild as opposed to sleeved tube. Also what type of steel has been used? I have seen h8monday's set up and it seems solid. Plan to use chevrolet 7/8 stud tre's. Any takers??
Alot of good info out there just can't seem to answer the above questions..
97 TJ with a few toys. |
Member # 33793
Solid steel is weaker than a thick walled DOM tube. I guess I really dont know how to explain it but, it is. If you doing steering links, build them with 1.5" .25" wall DOM. I guess if your really looking for beef, you could sleeve your tie rod with 1.75" .120 wall DOM. Thats a big link and you might have clearence issues depending on your setup though. My personal experence with this is my Currie steering setup, the tie rod is solid 1.25" steel and I bent it on the very first hard slam. Me and everyone else running the kit that has slammed down on their tierod hard bends it everytime. Pretty shitty for a $100 plus tie rod. I'm going to build a new one with 1.5" .25 wall with heims and I really dont see that link frowning after the first few times it kisses some rocks.
-Michael
...just another daily driven TJ on 37's... |
Member # 52
Whatever......solid works just fine. Mine is 1.25" stress proof. It has good memory and stays straight. Down side is, you have to have access to a lathe, or pay someone to run it. And yes, 1.25" x .250" DOM will work great too with welded inserts that take 7/8" TRE's. Either way it is ok.
Rockzombie Smurf |
#4 (permalink) | |
#5 (permalink) | |
Member # 62
Jeff Neves |
#7 (permalink) | |
not necessarily true. assume two pieces of round stock made from the same material. the hollow piece will be less resistant to bending.
rob [URL="http://www.tr-motorsports.com"]TR Motorsports #108[/URL] |
#8 (permalink) | |
1.25x.219 wall DOM OR 1.5x.344 will allow you to just tap it for 7/8" TRE
B-RAD Fabrication TDO DYSFUNCTIONAL ROCKCRAWLERS |
Member # 13820
It is High steer, so I am not super concerned about impacts. I was going to just buy one,, but I can't find anyone who will let me spend my money everyone wants to get back with me and I never hear a word.. RANT DONE
I have access to a lathe, and sourced the left hand tap.. I was thinking 1.250 thick solid rod with threaded ends. Hard to uderstand that solid is weaker than dom,,even heavy wall, but I do not have any stats or formulas to argue so..........
97 TJ with a few toys. Last edited by Rio_Grande; 12-12-2004 at 11:16 PM. |
Member # 30232
check this out http://mo-offroad.com/Tie%20rods.htm
thick walled DOM is NOT stronger than solid of the same quality steel.
anyone who thinks otherwise needs to turn on their brain and read this: /forum/jeep-hardcore-tech/235249-long-arm-mtl.html (the only exception to this is when the extra weight is helping to bend it, in practicality, this applies to cranes, not tie-rods.)
awshifting.com awshifting@gmail.com |
#12 (permalink) |
Member # 62
All you guys saying tube is stronger I would love to hear an explanation of how tube is stronger then solid of the same outside diameter...
Also a good source of steering components is www.rockstomper.com can make it as beefy as you want at a good price
Jeff Neves |
#13 (permalink) |
http://www.physicsforums.com/showthr...970#post272970
The bending stress in the beam (pipe) is given by the following: ![]() where M(x) is the external moment as a function of x (same for both since loading conditions are the same), c is the distance from the neutral axis (will equal d/2 in this problem when finding the maximum bending stress) and I is the area moment of inertia (aka second moment of area) which is a function of the cross section geometry. (If you look at the Euler beam bending formula, you will find the same dependence of deflection on moment of inertia, which is the key to this problem.) The moment of inertia of the solid pipe: ![]() The moment of inertia of the hollow pipe (same outer diameter, d, along with inner diameter of di): ![]() Since the amount of bending is inversely proportional to the moment of inertia, the pipe with the lower moment of inertia will bend more. Looking at the equations you should see that the hollow pipe will bend more. Last edited by Recurve; 12-13-2004 at 08:32 AM. |
#15 (permalink) | |
Doublewide engineer
Member # 6971
And that ladies and gentlmen is what a high tech bitch slap looks like.
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
#16 (permalink) |
I run a 1.25" solid bar (mild steel) drag link. It was drilled/tapped on a lathe to accept chevy 1/2 ton tie rods. I didn't bother with the left hand tap. who cars, its only a minor pain to initially adjust it. They are threaded in far enough, that even if it managed to thread it's way all the way down on tie rod. The other side would still have 2" of thread in contact.
Haven't had any problems with it in 2 years. and honestly, I don't want to be in the rig if I am ever in a situation that causes it to bend. |
#17 (permalink) | |
Member # 52
Rockzombie Smurf |
#18 (permalink) |
Moderator
buddies is 1.5" solid 7075 Aluminum. Where does it fit in this strength comparison?
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab Last edited by apeters89; 12-14-2004 at 05:11 PM. |
#19 (permalink) | |
Member # 52
Rockzombie Smurf |
#20 (permalink) | |
Moderator
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab |
#21 (permalink) |
Low Range Drifter
Member # 7903
I've got the inverted-T steering using the big GM stuff on my junk. I'm using the some thick ass DOM and directly tapped (left and right hand); I can't remember what it is, seems like 1 5/8" with 3/8" thickness.. my memory sucks. Here's a pic from when I first put it on, it's low and a rock dragger. I'm going full hydro, so this is only a short-term solution.
![]() Anyway, the tube is fine, but the rod end is bent to shit. So the rod end is the weakest link. good bye.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig Thanks to Drivetrain Specialists and PAC Racing Springs for your support |
#22 (permalink) |
Member # 7875
I run a 1.5" chunk of 4130 that is tapped RH and LH for UNF 3/4 - 16 - never ever had an issue - never will (except maybe killing a 3/4" rod end
) I am full hydro these days so the tab is left over from the assist and draglink days... Just too lazy to cut off a 1" thick tapped tab...
