klune to np231c - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2005, 09:01 AM   #1 (permalink)
Member # 27287
klune to np231c
currently in the process of installing a klune in my 88 yj, already have taken the np231 apart once about three years ago and installed the advance adapters 32 spline output. since my yj is a 4 cyl I need to replace the input on my t-case from 21 to 23 spline so I dont have to use any more adapters. I was going to try to find a 23 spline input and install it in my case. but I was reading another post and am interested in the np231c with 23 spline input, heavier chain, cogs, etc. I also have mechanical speedo, and want to retain it, any input would be appreciated, what vehicle and year would most likley have the 231 c with 23 spline thanks
87 YJ
Marc Daniels is offline   Reply With Quote Quick reply to this message
Old 01-23-2005, 01:44 PM   #2 (permalink)
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
i have a 23 spline input for sale $100 and i pay for shipping.
Only in a Jeep
Murfman is offline   Reply With Quote Quick reply to this message
Old 01-24-2005, 11:02 AM   #3 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Dont put any NP231 behind a klune.
Get a gear driven case.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 01-24-2005, 11:22 AM   #4 (permalink)
GaryTJ's Avatar
Member # 36995
I kinda agree.. The 231 planetary system is too weak for the reduction. It will break easy. If you are going to run a NP case behind a klune you need to build it out of a 241 planetary (6 gear instead of 3) and use a chevy chain and gears. By the time you get it together and strong enough and the h/d output and all, you are right there where an atlas would be in cost. (Unless you have all the parts laying around)
but then again, it is just an opinion
Life is not about a pretty body, it is about sliding in at the end, all used up and worn out, going "Man, what a ride!"
GaryTJ
GaryTJ is offline   Reply With Quote Quick reply to this message
Old 01-24-2005, 11:34 AM   #5 (permalink)
Moderator
Member # 10249
You put a $50 ford NP205 behind a 4:1 klune and its about half the total cost of an atlas and has better gearing options.
Dave
AZ Undertaker
Old 01-24-2005, 11:49 AM   #6 (permalink)
GaryTJ's Avatar
Member # 36995
Another option...
GaryTJ
Old 01-24-2005, 08:45 PM   #7 (permalink)
Member # 27287
205 behind klune
I like this option, didn't even think about it, has anyone run this, what is the input spline count on the 205, and will it be able to be used with a flat crossmember, what about the speedo. thanks Marc
87 YJ
Old 01-25-2005, 04:58 AM   #8 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
I'm assembling this right now. The Ford 205 uses a 31 spline input. You can buy a universal speed senser from Napa part number:ECHVSS100 to reconnect you speedo. I hope to have a flat belly pan, and with the clocking of the Klune V, it *should* be rather simple.
My set up is going to be:5.0L/C6/Klune/205.
sodaboyYJ is offline   Reply With Quote Quick reply to this message
Old 01-25-2005, 09:02 AM   #9 (permalink)
Member # 30098
Interesting. I was wondering about that. I was talking to the Klune engineer and he did not seem to be aware of issues breaking a 231 behind a Klune, but it seems reasonable to me. That is a lot of reduction in front of that t-case. I know JB conversions sells a beefy 231, but I have not shopped for cost....no doubt the 205 is waaayyy cheaper.
Are your comments tied to tire/motor size, or is it just not a good idea, even with 37s and the 4.0 motor?
The only issue I have with the NP205 is size and weight, but strength is really nice, is it not? As I think about it, the 2:1/4:1 combo would probably be more versatile than the 2.7:1/4:1 combo. Hmmm.
[FONT=Arial]Feature Editor C4x4.com. Former owner of project This Old Scout. New owner of Project 'Blue Oval YJ', an 89 Wrangler with lots of potential!
[/FONT]
mtroy is offline   Reply With Quote Quick reply to this message
Old 01-25-2005, 12:44 PM   #10 (permalink)
GaryTJ's Avatar
Member # 36995
My comments are tied to having been inside lots of these t/cases and seen how the case is built and the stress that would be placed on the gears at the gear multiplication that we are talking about. With only 3 gears spread out at that kind of stress it would be real hard to hold it together in an aluminum case.
When I went to the v-6 and nv4500 and 38" sx's in mine, I did the T/case how I described to get it hold together better. It has been kind to me, but it is showing a lot of wear after 3 years of hard wheeling. I believe if I had not gone with the h/d planetary it would have come apart.
GaryTJ
Old 01-25-2005, 06:08 PM   #11 (permalink)
Member # 27287
klune to np205
Talked to julie at klune today, they do make an adapter for this setup to work, but recomended to stay with the 231,and go with the 23 spline input, and I already have the HD 32 spline output that she also recomends, this is considering the overall length, weight, and because I am also running the 4 cyl. If the 231 breaks, or if I eventually do the engine swap, all possible adapters are available for a reasonable price. She said they were unaware, of any problems with the 231 t case behind the 4 cyl and 4.1 klune. Since this setup is fairly simple, I will probably stick w the 231, but I will be on the lookout for the 435 to 205 combo is case any problems arise. thanks marc
87 YJ
Old 01-26-2005, 12:16 PM   #12 (permalink)
Member # 25371
since i have a klune in my TJ i feel i can reply here, i used the bronco D20 case and the 4:1 klune and was able to reuse my driveshaft that i had with the 231 w/ SYE.
also be aware that if you buy a 21 spline input on a KLUNE the only other option is a 23 spline input, i know this cause i just e mailed Julie about swaping tranny's.
oh and i would never go back to only having two speeds again after having 3.
okie
oklahomarocks is offline   Reply With Quote Quick reply to this message
Old 01-27-2005, 04:22 PM   #13 (permalink)
Member # 27287
klune input
I also talked to her about it, if I were to do the 4.3 swap to 700r4, to klune, to 231, you send back the box, tell them what combination you will be running, and they will change the input so that you can mate it to the 700r4, cost being around 200.00, thats a pretty good deal, considering the cost new. just thought I'd relay the information.
87 YJ
Old 01-27-2005, 08:04 PM   #14 (permalink)
Ehhhhhh...
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
A crawler in front of a 231 is fine for a 4cyl. Probably a little iffy behind a 6cyl though.
desertCJ is offline   Reply With Quote Quick reply to this message
Old 01-27-2005, 09:01 PM   #15 (permalink)
Member # 27287
sorry, meant to say 4.3 to 700r4 to klune to 205.
87 YJ
Old 02-21-2005, 03:53 PM   #16 (permalink)
Member # 35042
I just got a Np241 Rock Trac Rubi t-case. Can this be put behind the 4:1 Klune? I know I will have 4:1 in both cases and it isn't that relevant for my auto XJ on 37's with 5.38 hp 44/9" 35 spline 5.43 gears, but just wondering. How much stronger is the Rubi case than the stock np231? How much weaker is the Rubi t-case than the Atlas 2?
Troy
bigredjeep1 is offline   Reply With Quote Quick reply to this message
Old 02-21-2005, 04:15 PM   #17 (permalink)
87yj38's Avatar
Member # 14010
Send a message via AIM to 87yj38
I have a Klune and Ford 205 in my YJ. You can have a flat belly, but you will need to cut the shit out of your floorboard on the drivers side. This is because of the frame mount boss the 205 has. Mine is clocked up so much that the boss hits my seat mounts on the drivers side. No big deal however.
My overall case length difference with the Klune and 205 was only 1.5" longer than my 231 with a SYE installed. I do not need a speedo so no help there.
87yj38 is offline   Reply With Quote Quick reply to this message
Old 02-21-2005, 07:17 PM   #18 (permalink)
wildman4x4nut's Avatar
Member # 21893
Troy
Yes you can put a Klune behind your 241. And why would you go with a 4:1? They also make a 2.7 so you would then have the best of both worlds.
TJ Builds:
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote Quick reply to this message
Old 02-27-2005, 12:31 AM   #19 (permalink)
Member # 26210
Send a message via AIM to GoingOffRoading
Hell I picked up my 231HD new for 925... not really atlas territory
Project D-Day...
I have a Lincoln 135t for sale... PM me for details
GoingOffRoading is offline   Reply With Quote Quick reply to this message
Old 02-27-2005, 12:57 AM   #20 (permalink)
Member # 35042
Sell it, U can get a 241 Rock Trac Rubicon case for about that. I just picked up 1 with 5K miles for $1,037 shipped and am going to run it in my 91' XJ with hp44/9" full width axles. What did U get the 231 HD from Advanced Adapters? Check out this on the 241 to 231 comparison:
http://www.rubiconowners.com/TransferCase.html
Troy
