how to pull an 8.8 axle? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2005, 08:10 AM   #1 (permalink)
Member # 8665
ok so i'm stupid
i got a detroit and don't see any access to the c-clips this bitch is supposed to have so i can pull the axles? i see the cross-pin and 90* around an "access-type" piece that don't come out.
what da fawk?
teach me
thanks
rockr is offline   Reply With Quote
Old 02-06-2005, 09:07 AM   #2 (permalink)
Member # 14731
On mine, I had to grind a ring gear tooth to slide the cross pin in. Thus, I remove the cross-pin bolt, slide out the cross pin, and then remove the c-clips and shafts. However, I have an Eaton, and not a detroit, so I can't help you out much. I just thought I would tell you mine, just in case it provided any insight.
Road Head is offline   Reply With Quote
Old 02-06-2005, 09:31 AM   #3 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
Tap the shafts with a hammer and push them in as far as possible. Should give you enough room to pull the clip.
ZJim is offline   Reply With Quote
Old 02-06-2005, 09:43 AM   #4 (permalink)
Member # 29593
On an 8.8 detroit you have to remove the pass side carrier bearing first so you can access the allen head bolt that holds in the crosspin. remove that bolt and the crosspin comes right out. Then like said above, tap in axles in with a hammer to acces the c clips.
trailxj is offline   Reply With Quote
Old 02-06-2005, 02:08 PM   #5 (permalink)
Member # 8665
yep------you are right. i just found my detroit manual and it gave the hot scoop. take off pass side bearing retainer and then back out the allen bolt and yep.....tap the axles inward to expose the c-clips....WA LAH
clean the allen bolt and hole........go buy some of that $6 a tube red loktite and lock that bitch back in.
thanks!
Old 02-06-2005, 07:40 PM   #6 (permalink)
Member # 15424
bravo:
90YJ | HDOR | WEBILT | ID4x4A
gripguru is offline   Reply With Quote
Old 02-06-2005, 07:42 PM   #7 (permalink)
Member # 15424
hands on demo:
Old 02-06-2005, 09:11 PM   #8 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
The above pic looks just like th Detroit from my Dana 35 c clip axle. You have to pull one of the pins next to that little doorway, and then it allows access to the C clips.
TexasBlake is online now   Reply With Quote
