Member # 3109
traction bar idea
My 91 soa YJ is getting a little crazy with the spring wrap. I broke my rear pinion yoke!
Ive seen the pics on here on traction bars. Ive searched I have a friend that came up with a idea that instead of using a shackle, that make a telescoping/traveling/slip through the upper arm???? Any opinions???
91 YJ, 4 banger, 4.88, Lockrite F/R, SOA, 35's, TJ flares 2002 HD1500 Crew Cab Jeep Hauler |
Member # 2095
I would think it would bind & not want to move when there is pressure on it
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's '02 Z71 |
Member # 940
That is what I thought. It sounds like something you will need to grease allot if nothing else. The shackle idea works and is simple.
WWW.PCRYO.COM Deep Cryogenic Tempering Service Find all my products at www.KICKASSOFFROAD.COM 916-434-6978 Custom Axles built to order. Got 40 spline? I have the hubs, spindles, and axles you need to kickass! Custom Hummer wheels and centers Axle Resplining |
if you have the angle of your bar so it lifts..instead of pulls..it could work....but its goin to get sloppier with wear....and what this does..is it lifts the vehicle....(the body) from the suspension..actually taking away from the tires....
the best is a two rod system that the bottom pushes and the top pulls...this way it cant wrap and the weight of the vehicle is pulled down onto the tires.
93 wrangler, dana 44 front r/c , arb 5.13 warn exteme duty outers, 9in rear, detroit, 5.13 3in alcan front springs, 2 1/2 skyjackers rear, spring over, traction bar, 37in ssr's 4.0 ax15 |
I had one like that on my cj for some time. The first one broke due to, too sharp of an angle from the lower bar. The second on broke the crossmember. The new one will have a shackle mounted setup. This seams to be the best for this type setup.
EMS Offroad |
Member # 1065
I use a goofy shackle set up.
The bushings give great wrap control, without being as rigid as a Heim. The "goofy", allows for the side to side angle of the axle, even with extreme articulation, along with forward and rear travel of the rear axle as it travels through its entire suspension cycle. It has nearly no adverse affect on articulation. They only cost a few bucks, and are fairly easy to fab, but a little time consuming as compared to a simple shackle. However you dont have to keep the shackle bolts loose, to allow for side to side, so the axle wrap control, and power to the ground, is more positve,(and easier on the bushings).
Pirates of the Rubicon Announcing is tough,..I need a beer |
Member # 3995
Here is a picture of the shackle set up we did on our wrap bar.. Works great
1973 CJ-5, 302HO, NP435, Atlas, Ford HP D60, Detroit,4:56 gears,3 Link,14" travel SwayAWay coil overs, PSC Full Hydro, Rear Dana 60, Spool,4:56 gears, 35 Splined Currie HD shafts, 4 link, 16" Rock Equipment Coil overs, 44x19.5 boggers 112" WB [URL=http://www.winingeroff-road.com]Wininger Off-Road[/URL] |
Newbie
Member # 8927
I just had an anti-wrap bar built for my SOA YJ. We used a shackle also.
"I refuse to belong to any group that would have me as a member." Last edited by Hackle; 04-23-2002 at 06:15 PM. |
Wait this ain't Tx..
When building mine they used a shackel...simple, and effective.
Here is the one that was built for my SOA FJ-40... Joseph A.
"There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter." -Ernest Hemingway '69 FJ-40 - under construction |
#10 (permalink) | |
Member # 3013
This is a great idea, does everything a simple shackle will do except bind up. I like it.
"Instead of being a trail guide, you should put on a clown suit and give pony rides at kids' birthday parties" 94 YJ. 5.0 HO, NP435, NP-203 W/3.2:1/NP-205 WMS doubler, Bilstein/Alcan suspension, 104" WB. 60's front and rear. |
#13 (permalink) |
Newbie
Member # 8927
Thanks for the comment but the credit goes to John at Hunter Offroad a local shop. I do most of my own work but that was well beyond my skill level.
"I refuse to belong to any group that would have me as a member." |
