Member # 27328
Traction Bar on SOA YJ-- Does it matter which side??
Seems like a stupid question, but a pretty experienced wheeler/ owner of a local 4x4 shop said that mounting the traction bar (ladder type such as one from Sam's or MORE) on the driver side caused some wierd handling on and off road. I'm talking about the rear Traction bar.
To run mine on the passenger side I will have to reroute my exhaust. Anybody running their traction bar on the driver side? I'm SOA on 1.5 RE SOA springs and 37" MTRs.
94 YJ Last edited by jbwrangler; 03-01-2005 at 01:30 PM. |
Member # 8274
I run mine on the drivers side, before and after the sbc/th350/d300 swap.
It's kind of in the way of the exhaust now, but not much. The only thing you notice with the SBC, is that in low range, when you put it in gear and hold the break, the entire suspension loads up on the side the bar is on. So right now the passanger side front end pitches down a bit.. its kinda cool Might just be the engine torque on the motormounts? |
Member # 62
passanger side is prefered because it will help counter act engine torque but drivers side shouldnt really be an issue... you will just notice more jacking then if it was on the passanger side.
Jeff Neves |
#7 (permalink) | ||
Member # 1636
Solve one problem, create another..... Last edited by chris demartini; 03-01-2005 at 03:08 PM. |
Member # 15404
sjlplat, what is that? I assume you built it. Not many people like the one link design and all but is that a hyd cyl with an adjustable bypass built in ???
Life begins where the pavement ends! |
sjlplat, i dont understand your traction bar. it looks like the red arrow points to a slip joint, which would completely negate the idea behind how that anti-wrap device works. however, the labia pink area looks like some kind of valving, as though that "slip joint" would act like more like a shock. please explain.
rob [URL="http://www.tr-motorsports.com"]TR Motorsports #108[/URL] |
Member # 8540
Very interesting sjlplat!
I had to run my Sams traction bar on the driverside due to my offset rear diff. My traction bar is only 1.5" off center and I have some real back anit squat - tourque over characteristics. If I could, I would mount it on the pass. side to counter act the torque over. Yes a 2.5L w/5:38s can cause torque over.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB Nothing is stronger than stupid... |
#12 (permalink) |
Member # 35369
Driver's side due to exhaust. Broke the top axle tab welds 2 weeks ago at the Hammers. Just bought everything to make another and move it to the passenger side. D60s front and rear with IROK 39.5s.
Not totally happy with the first one. About the 4-link..... Next major project
93 yj |
#13 (permalink) |
Evil Twin
Looks like adaption of a pull bar from the roundy-round sceen... I'm planning a similer with some rubber/polly busings with some preload adjustments...
I do like the hydro cylinder deal. seems like it might be easier to tune and maybe depending on ammounts or type of fluid used to offer some different dampening characteristics... Please post back with some more info.. But bassically its NOT directly affecitng AS.. And as for the na-sayers.....imho. with adiquate leaf packs some wrap (google: forward bite) can be a good thing... good read on forward bite here http://stockcarracing.com/techarticles/59459/ quote from article.. “The torque absorber allows the rearend housing to wrap up and thus takes that instant shock away from the rear tires when a driver first jabs on the gas pedal,” says Wayne Lensing of Lefthander Chassis. While they arnt dealing with a low psi tire that is also absorbing torque or terrain that changes by the foot. I still has some merits.. just my .02 based on my internet research... We can rediscover staggard shock placment tomarrow Just happy to see other non-conformists out there
Mike Yager - Jeep TJ Build Up - Ecotec, Toy axles etc.. Ecotec - Technical Info E450 Ambulance VRAY (YAger RV) VRAY 2006 E450 - Ambulance Cummins Diesel Swap |
#14 (permalink) |
Member # 27328
Good info. I guess alot factors into the jacking/antisquat other than the location of the traction bar, such as spring stiffness, shocks, etc.
I think that I will just move my exhaust so I can put the TB on the passenger side, alot of my exhaust got trashed on my last trip anyway. The center bar looks interesting. Nice job. I'd be interested to learn more about it. JB
94 YJ |
#16 (permalink) |
Member # 31688
sjlplat's traction bar can also be seen here: /forum/jeep-hardcore-tech/326334-xj-rears-yj.html
The cylinder has 3/4" play in it. Hopefully he'll chime in and tell you the rest or check out the thread above. Pretty good idea and a little outside the box. Also some more alternative traction bar info (not Sam's style) in this thread:/forum/jeep-hardcore-tech/332171-cant-friggen-find.html Last edited by fubar73cj5; 03-01-2005 at 10:25 PM. |
#17 (permalink) |
A little more info on my link:
The link was designed and built by Steve Lesher of Over the Top Customs. He uses a hydraulic cylinder and limits the slip to 3/4" to prevent binding and tilting of the diff at full droop. Since the cylinder rotates 360 degrees, it will not bind when flexing side to side. Granted, it will not completely eliminate axle wrap, but it does keep it under control. Steve runs it under his Scrambler with a full-width 14B and 39.5's under 4" YJ springs. After seeing his bent spring packs prior to the traction link install, and knowing how hard he wheels it, I was sold on the design. My rig runs the same full-width 14B on 39.5's, but I run stock XJ springs out back with an F150 leaf added. The parts list consists of enough tubing to build the crossmember and diff hoop, 4 tabs, 2 heims, 2 link inserts, and a hydraulic cylinder. |
#18 (permalink) |
is the 3/4" travel unrestricted? or is there somehow some dampning too it? I have a cylinder lying around and I was thinking about doing this but with it almost full of oil and just a little air. the air would allow for a little cushion to it.
awshifting.com awshifting@gmail.com |
#19 (permalink) | |
#20 (permalink) |
i have ran mine on the drivers side, no problems with it for over 3 years. But after the 350 i did notice when u really open it up, the drivers side will lift up a little. But its not built for the street so i really could care less, it works great for what i need it for!
TJ/Wrangler MUTT... Dana 80 37 Spline, Discs :) Bling HP60 Dendenbears,Chromos/Longfields FULL HYDRO 47LTB's Locked with C&R BreadLocks 350TBI Sm465 203-205 Gen2 Doubler [SIZE="5"][B][COLOR="Blue"]ROCKZOMBIES4X4.com[/COLOR][/B][/SIZE] R.I.P. Dave "Kyle" That was one hell of a ride, I will never forget! |
#21 (permalink) |
im about to build my traction bar and im trying to decide how to locate it. itll be on the drivers side, i have a yj and my exhaust is on the pass. side, but, what im thinking of doing is welding it to the pumpkin section. i have an 8.8 and since i cant post pics ill just refer to u-joints picture. i was thinking of placing the outer mounting tab on the edge of the pumkin that the drivers side tube goes in, and then setting the other mounting bracket in towards the pumpkin and using the rib to help locate it and strengthen it. any thoughts on this? i know its cast iron, but is there a good strong way to weld to it? im going to have my buddy whos a master welder do the welding so im not worried about the strength of his welds just the integrity of the surface. thanks
The mountains are calling and I must go. -John Muir Last edited by currupt4130; 03-02-2005 at 11:54 AM. |
#22 (permalink) | |
#23 (permalink) |
Member # 27328
U-Joint, lokks like we have pretty much the same set up... RE SOA springs, 8.8, MORE traction bar.... You got any pics of the Cross member end of that traction bar? I'm debating on how to build mine.
94 YJ |
#24 (permalink) | |
Member # 31688
Look at the links in post #16 |
#25 (permalink) |
Member # 8274
I bent my original bar (1.5" sch40, triangulated) at the end of my driveway right after I put the V8 in.. actually it was exactly at the same time as the D35 blew.
I built this one, and decided that I could try something new if I wanted. It's a frame, with 2 bumpstops that the bar "floats" between. Its all welded to the flat skid. In practice, at rideheight the bar sits against the top bumpstop, and i get a slight "thunk" if I get on the breaks fast, and then on the juice. Just enough to tell you it's there and working. ![]() It's worked well so far, what i really want to do is get it on a ramp and then see how it acts when the suspension is all pretzled up. ![]() edit: excuse the nasty welds. Last edited by Inferno; 03-02-2005 at 04:20 PM. |
