Limiting axle wrap idea for less than $10. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-04-2005, 12:59 PM   #1 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Ok, from recent thread, (/forum/jeep-hardcore-tech/332171-cant-friggen-find.html) about using tractor links to limit axle wrap, I started thinking about another way, which would utilize chains, or steel cable, or limiting strap to limit axle wrap, and pinion angle movement.
Not sure if this woud work, but the theory seems right, what do you guys think?
Basically on each side of rear axle utilize a chain in the front and rear, over springs, limiting axle torsion. They should not limit axle flex, since the length between the front and center (A-B), and center and rear (C-B) does not change, so teh chain should allow the drop without problems. Teh chain tension could be adjusted using some type of stud with a hole in head and nut like O====
For background the pinion angle would pull up when torque is applied to the rig moving forward (opposite force).
Reasons to look into this approach:
1- Really easy and cheap to make (about ten bucks in chain and parts)
2- Seems to eliminate\avoid axle wrap
3- light
4- less stuff to bang around on rocks
So flame away, but what do you think?
From page two, but here is the setup in place, and worked out great to help minimize wrap. Again, it is not a 100% anti-wrap solution, but a very easy way to help reduce wrap, and can be built very easy for about $10 , Also light, and does not limit flex
geberhard is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 12:59 PM   #2 (permalink)
Moderator
geberhard's Avatar
Member # 5861
This is the pic of the tractor bar link for comparison. Instead of the tractor link, the use of two chains (front and rear), could provide a similar solution.
** reduced pic size**
Old 03-04-2005, 01:15 PM   #3 (permalink)
Member # 11998
Send a message via AIM to BrettM
clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink clink
that's the sound of you going down the trail, besides that it sounds pretty good. maybe a cable would be better.
awshifting.com
BrettM is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 01:25 PM   #4 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Brett, LOL , I can even attach some cow bells I would use a hose heated and heat wrapped around the chain, so less clink and less rust
Gui
Old 03-04-2005, 01:40 PM   #5 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
the theory behind it sounds good. i like the one you have pictured tho.
rob
87JeepWrangler is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 01:41 PM   #6 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
holy big picture chainman
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 01:42 PM   #7 (permalink)
CSP
Member # 1533
I don't see how you can figure that the lenght wouldn't change as the springs compress. If they didn't change we wouldn't need shackles at one end.
CSP is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 02:24 PM   #8 (permalink)
ItsaCJ6's Avatar
Member # 6340
Droop would be severly limited, since the force reduction will only work if the chains are tight.
I would think a shock would be a better choice, though it might not elimiate all spring wrap.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 03:46 PM   #9 (permalink)
Member # 11998
a very very stiff shock. anybody got ideas?
awshifting.com
Old 03-04-2005, 04:21 PM   #10 (permalink)
Member # 14731
Yeah, Rough Country has some stiff shocks J/K, their springs were nice, but the shocks left a little to be desired, but for the $$ and I was a broke college kid, it was a good deal.
Road Head is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 04:41 PM   #11 (permalink)
Member # 28566
That setup would actually rotate the axle with spring compression and droop.
A good ol' ladder bar is probably still the cleanest setup.
LilRocky is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 04:46 PM   #12 (permalink)
Moderator
geberhard's Avatar
Member # 5861
What about if the rear chain is actually wrapped by the leaf? The distance should not change at all at flex. Like this:
I think I will get some chain, cut it up and see if it would work
Gui
Old 03-04-2005, 06:41 PM   #13 (permalink)
Member # 62
Gui
I think this setup would be a better option.. I don't think the rear chain would limit droop however it would likely limit compression. I think the problem with the chain idea is to follow the arc as closely as possible the rear chain would need to slop down as it goes towards the rear of the vehicle.
Jeff Neves
NE-RokToy is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 07:54 PM   #14 (permalink)
Member # 9513
While you boys figure this out I'm going wheelin
what I used to drive---63 CJ5 350 SM465 D18 Warn O.D. 5:38s D30 &D44 Detroits,
v8cjmark is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 08:55 PM   #15 (permalink)
Member # 25424
Just use a track bar and a shackle and forget this crap, is your time not worth anything?
When your down to one wheel drive pull the cable.........or back up and give it one more try!
SEEJAY7 is offline   Reply With Quote Quick reply to this message
Old 03-05-2005, 12:20 AM   #16 (permalink)
Member # 20592
Send a message via AIM to gumbojeepyj Send a message via Yahoo to gumbojeepyj
this sport grows and progesses by people thinking outside the box.
granted i think a regular ladder type bar is the most effective way short of going 4 link to eliminate axle wrap, but i admire his willingness to try something different.
Blake
http://www.lockitupoffroad.net
gumbojeepyj is offline   Reply With Quote Quick reply to this message
Old 03-05-2005, 05:35 AM   #17 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
Don't bother with the chain on the rear of the spring. The only one that's gonna do anything positive is the one forward of the axle.
McMaster-Car has a sleeve, used to protect hydro hoses, to cover the chain to stop the clinking.
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote Quick reply to this message
Old 03-05-2005, 12:02 PM   #18 (permalink)
ItsaCJ6's Avatar
Member # 6340
The "C" chain in your second drawing is doing nothing. since as the axle wraps the spring in the front sees the most twist.
The "C" chain does not restrict the bottom of the axle moving forward since the whole shackle moves with it. This still allows the axle to pivot at "B"
I would agree with SodaboyYJ just run the front chain and see how bad it is.
Marc
Old 03-05-2005, 01:39 PM   #19 (permalink)
Member # 41131
I have recently used the technique used in JP mag (insert flaming here...LOL) by adding a leaf on TOP of the main leaf. It needs to be the same length as the main leaf.
We recently put a D-60 into the rear of an XJ and did this. This is wtih almost 8" of lift, 36" tires and...ZERO...I repeat ZERO axle wrap and flex was not hindered at all.
I am in the middle of an MJ buildup (my own rig) and used the stock rear leaf packs SOA and added a leaf to the top.
Brett you'll like this...We're doing the front leaf conversion with 7 leaf waggy springs with an extra waggy long leaf in the pack and then a leaf over the main leaf for axle wrap. If it works as well as it does on the XJ it is a VERY cheap and easy solution to axle wrap.
043500 is offline   Reply With Quote Quick reply to this message
Old 03-05-2005, 04:41 PM   #20 (permalink)
Member # 22819
Got some pics of that?
87 Sami
DD Chevy....
jlake1 is offline   Reply With Quote Quick reply to this message
Old 03-05-2005, 05:55 PM   #21 (permalink)
Member # 41131
Pics of...???
Old 03-05-2005, 06:12 PM   #22 (permalink)
Member # 22819
The leaf on top of the main leaf to limit axle wrap. I guess I was just assuming it couldn't be as simple as it sounded....
87 Sami
DD Chevy....
Old 03-05-2005, 06:48 PM   #23 (permalink)
fubar73cj5's Avatar
Member # 31688
Wouldn't this hinder droop considerably? Did you run your set up without the added leaf on top before and see if flex was really effected? Sorry, I don't get JP
fubar73cj5 is offline   Reply With Quote Quick reply to this message
Old 03-05-2005, 07:00 PM   #24 (permalink)
Member # 20592
absolutely 100% sure that adding a spring on top will not reduce axle wrap to ZERO. even teh beefiest spring packs have a bit of axle wrap. dont believe me? strap a vid cam under your junk pointed at teh rear pinion and video yourself driving.
Blake
Old 03-05-2005, 07:27 PM   #25 (permalink)
Member # 15049
also, say goodbye to up travel...
1990 V10 Blazer
sw99 is offline   Reply With Quote Quick reply to this message
