Need Help Asap!!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2005, 04:31 PM   #1 (permalink)
Member # 19744
Need Help Asap!!!!
92 4L 6 cyl motor. new started all fuses are still perfect. getting no power to starter i guess. I turn the key to the on position and every comes on as normal then turn to crank and I get nothing. no sounds no click, nothing. any ideas? please help
Kegcrawler is offline   Reply With Quote
Old 03-17-2005, 04:38 PM   #2 (permalink)
Member # 34067
ummm,did ya take the starter off to go and get it checked to see if it is good?
davidt is offline   Reply With Quote
Old 03-17-2005, 04:39 PM   #3 (permalink)
Member # 19744
I put a brand new starter on it tonight and still nothing
Old 03-17-2005, 04:43 PM   #4 (permalink)
Member # 37720
Send a message via AIM to Mr Puddleman
have you checked grounds ?
'72 CJ5, 360/T-15/D20 D44f/Eaton Rear, Soa
Mr Puddleman is offline   Reply With Quote
Old 03-17-2005, 04:49 PM   #5 (permalink)
Member # 19744
which grounds do i check for? the ground to the block is good and battery is good, what other ones should i check?
Old 03-17-2005, 05:42 PM   #6 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
corroded battery cables?
shit on or in the battery terminal ends?
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote
Old 03-17-2005, 06:45 PM   #7 (permalink)
Navy's Avatar
Member # 22626
The ignition tumbler could be crap or the rod to the start boxcame off.
Navy is offline   Reply With Quote
Old 03-17-2005, 06:50 PM   #8 (permalink)
HeiserOilMotorsports
Po' riggity's Avatar
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
make sure the wires connected to the starter are on tight, and if its check the battery cables for corrosion. If that stuff checks out ok, and you still aren't getting any action out of the starter, then pull the starter, and return it for a new one. Ive have one starter that was bad as soon as I got it, out of the box.
Scott
HeiserOil Motorsports:
Crawlin' For Crohn's
Friends of San Bernardino National Forest (website not yet complete),
brought to you by Sbwinvps
Originally Posted by Alpine4x4 View Post
y'all know my flatbill hats make me the best desert racer out there!
Po' riggity is offline   Reply With Quote
Old 03-17-2005, 09:56 PM   #9 (permalink)
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
check the starter solenoid where it screws to the fire wall, if it gets corroded there, it will affect your starting. also, try and short across the starter and see if it cranks, if it does, the problem is up stream
Only in a Jeep
Murfman is offline   Reply With Quote
