NP 231 Input question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2005, 10:51 AM   #1 (permalink)
epic proportions
cherokee kidd's Avatar
Member # 27832
I purchased a 231 out of a wrangler(square headlight era) with a 23 spline input that is short. I have a tf 904 to install it to but that needs the long input. I couldn't call anyone because none of the adapter places I deal with are open on the weekends. I know the difference in length is .9 of an inch and it seems to make good contact on the shaft with the short input so all I could see the extra length being for is to seal the rear of the tranny. I have an old 231 (85 or 86) with the long input but a different cut on the gear. If I took the length I need off that shaft and slid that on the trans shaft first as a bushing would that be ok. I have access to a lathe so it can be cut accurate. I might be getting carried away becuse the input might be cheap but I can't find out till tomorrow and this is bothering me
Bink'sFabrication
NEW SHOP in Salida, Ca
facebook.com/binksfab
Tube bending, mig and tig welding, rollcage design, and cnc plasma cutting avaliable. For info call (209)402-6433
cherokee kidd is offline   Reply With Quote
Old 03-20-2005, 03:24 PM   #2 (permalink)
Newbie
Member # 44160
The problem is your short input shaft (NP231) will not have enough length to grab the seal in the adapter between the trans/T-case, thus will dump ATF all over and make big messes and make you mad (BTDT).
If you dont change to the longer input, here is what you need:
TeraFlex sells it under this part number:TL621
Works great to slove this problem.
CODE5337 is offline   Reply With Quote
Old 03-20-2005, 03:42 PM   #3 (permalink)
epic proportions
Member # 27832
Awesome thanks very much. I'll call them tommorrow
Bink'sFabrication
Old 03-21-2005, 07:26 AM   #4 (permalink)
Go_Vols's Avatar
Member # 12691
Clarification -- you have a TF904 with a long OUTPUT shaft, and a 231 with a short INPUT (female) receptacle, right?
If so, cut output to a correct length, check the tolerance, slap on some RTV and bolt'em up!
"Lil'T" - 99TJ RC60/14B/Klune 4:1/Atlas 6:1/H1/44"TSLs/PSC Full-Hydro...
Rollover Ratio = 1.0:3
[url]www.tgtwoffroad.com[/url]
Go_Vols is offline   Reply With Quote
Old 03-21-2005, 11:46 AM   #5 (permalink)
Newbie
Member # 44160
So how does this affect the length of the adapter (where the seal seats)?
