CJ5 restoration - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-11-2005, 02:53 PM   #1 (permalink)
Member # 47276
CJ5 restoration
I am putting a 4.3L vortec from a 94 blazer in my 82 CJ5. What do I use for a Fuel tank so the blazer fuel pump will install?
Randy Weber is offline   Reply With Quote
Old 05-11-2005, 02:57 PM   #2 (permalink)
Member # 11154
Autozone carries an external fuel pump that I have used with great results. AC-Delco PArt number EP240. It runs about $65 and you can just add a return line to your old tank. (I soldered a new fitting into the sending unit on top of my tank.
OCNORB is offline   Reply With Quote
Old 05-11-2005, 06:24 PM   #3 (permalink)
]2eDeYe
stepfor's Avatar
Member # 20045
That is not what I'd call a "restoration"
]2eDeYe
Jeep n stuff...
If it ain't broke, don't fix it.
stepfor is offline   Reply With Quote
Old 05-11-2005, 09:28 PM   #4 (permalink)
4x401cj's Avatar
Member # 37244
You should change that that to "CJ5 Desecration"
4x401cj is offline   Reply With Quote
Old 05-11-2005, 10:17 PM   #5 (permalink)
Member # 3976
Send a message via ICQ to CJ5-Man Send a message via AIM to CJ5-Man
you can fit the fuel pump in the stock tank.
What I did on mine is cut the tube off the pickup and put the fuel pump on. I took the grommet for the wiring off of a gm sending unit and used that along with the support bracket for the fuel pump.
Its a tight fit, but it will go in there.
CJ5-Man is offline   Reply With Quote
