D.O.T.-approved racing harnesses? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2005, 06:57 AM   #1 (permalink)
Member # 39799
I'm about to get my '82 Scrambler on the road, and I'm trying to figure out my rear seatbelts. I'm running a full soft top with a fold-n-tumble rear seat for my two daughters (almost 5 yrs. and 2 yrs., respectively). My older daughter is now in a booster seat, and I don't want to use just lap belts in the rear.
Are there any 5-pt. racing harnesses that are D.O.T.-approved? I have yet to find them. Any input is greatly appreciated.
Craig
1958 Jeep FC170 "Patina Rod", '97 XJ 2-dr. (14-year-old Mira), '00 XJ 2-door (12-year-old Maeve)
1x1_Speed_Craig is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 07:34 AM   #2 (permalink)
ItsaCJ6's Avatar
Member # 6340
Use both
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 08:18 AM   #3 (permalink)
Member # 39799
I found these through a Google search. Anyone have experience with them?
Schroth Harnesses
http://www.rennsportsystems.com/schroth.html
Another Schroth link:
http://www.modernperformance.com/all/schroth.shtml
Craig
Old 05-17-2005, 08:36 AM   #4 (permalink)
Peter_C's Avatar
Member # 34538
Schroth is the only harness I know of that is D.O.T. I have a pair of Scroth Auto Controls in my rig and am very happy with them. I spent hours researching what to buy and could not find another 3 or 4 point that was D.O.T.
Peter_C is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 09:22 AM   #5 (permalink)
P&T Jeeps's Avatar
Member # 3916
I haven't done any research on the topic but I don't see how a 4-point harness, properly mounted wouldn't be DOT approved. IMO, the obviously protect beyond the typical stock vehicle constraint system.
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
P&T Jeeps is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 09:25 AM   #6 (permalink)
Member # 7903
P&T - don't try & apply logic when thinking DOT or any other govt agency.
Schroth is the one I remember reading about. I knew I would recognize the name once I saw it...
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 10:14 AM   #7 (permalink)
Member # 23574
Send a message via AIM to sintax
kind of backwards thinking, but to get around the DOT bullshit just mount a set of factory seatbelts. You can remove them after you pass your safety inspection.
Kind of like when I used to drag race my old nova, they told me that since my 5 point was over X amount of years old, they were not "legal" at the track, but I they said that if I had the factory lap belt, i'd be good to go.
sintax is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 10:25 AM   #8 (permalink)
Member # 28913
NHRA rules state harnesses must be Replaxed every two years.
I have asked a Few law enforcement officials regarding harnesses in place of seatbelts and I was told that "even though they are not D.O.T. approved they would never cite a ticket for a driver using them in place of standard belts, due to the increased safety, However that is them and not all police."
When will it ever Run??????
jtgroover is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 11:19 AM   #9 (permalink)
Member # 39799
Yeah, I spoke with a buddy of mine this morning who is a local Sheriff's Deputy here in Michigan. He said that anything D.O.T.-approved would be fine.
In the situation where the harnesses/seatbelts came into question, I think a lot would depend on the officer you ran into (not literally, I hope), the mood of that officer at that particular time, and whether or not he/she is a Jeep fan.
Craig
Old 05-17-2005, 11:34 AM   #10 (permalink)
Member # 39371
Send a message via AIM to currupt4130
i think ive always heard that they have to be retractable to meet DOT approval, i could be wrong, just what ive picked up. i run both in my jeep, i usually just wear my lapbelt and let my factory 3pt hang on my cage
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 02:52 PM   #11 (permalink)
Member # 30590
i wouldn't bother, I've had unapproved four point harnesses for two years and haven't had any problems with the cops or inspection.
73jeep is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 03:11 PM   #12 (permalink)
Member # 39799
Understandable viewpoint, but do the words "child endangerment" mean anything? Racing harnesses are probably a lot safer than the OEM seatbelts, but they'll be used for my 4-year old and 2 year old daughters. If I did get stopped and an officer had an issue with it, non-compliant harnesses for young kids might open Pandoras box. I definitely want safety, but I want to do it by-the-book.
Craig
Old 05-17-2005, 07:11 PM   #13 (permalink)
1972CJ5+1's Avatar
Member # 15811
I am not sure about the DOT. ( who really ever is ) I use these: Seat Harness
If you check the link, you will see that they are just a normal seatbelt with the upper two points added. Mine release with a normal seatbelt release for the uppers also. They mount in the normal location using the normal hardware, and can be had with a retractor also if that is an issue. If your application calls for a lap belt, this will cover that, plus some. I'm not sure once you get to the newer applications where a 3point is required. I have put these in more than one vehicle without issue. I got mine from here:4 Wheel Drive Hardware for about $70 a pop including mounting hardware. They have a number of varieties, mounting styles, etc.
[COLOR="Lime"][SIZE="3"][B]booger weldz [/B][/SIZE]alternate account[/COLOR]
1994 fzj80 Elockers front and rear, 35 km2s, 10k winch, coolest station wagon in the world!!
[COLOR="Silver"]♣[/COLOR][B][COLOR="Lime"][FONT="Arial Black"][B]Bink'sFab[/B][/FONT][/B][/color][COLOR="Silver"]rication[/COLOR][COLOR="Lime"]♣[/COLOR] -
1972CJ5+1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 07:28 PM   #14 (permalink)
TexasBlake's Avatar
Member # 9722
I drive my jeep with 5 points all the time. No cop or inspection station has bothered me.
TexasBlake is offline   Reply With Quote Quick reply to this message
Old 05-17-2005, 08:34 PM   #15 (permalink)
nhgpnut's Avatar
Member # 42521
Send a message via AIM to nhgpnut Send a message via Yahoo to nhgpnut
in a car seat[for a child ] i always thought there was already a 5 point harness.abooster seat i can see your problem.but i believe 4wd hardware sells 5 point seat belts that buckle the nomal way.with children my biggest concern would be if they could release themselves.in the event of an accident.
nhgpnut is offline   Reply With Quote Quick reply to this message
Old 05-18-2005, 02:47 AM   #16 (permalink)
Member # 39799
Good point. To clarify, my older daughter just moved out of her convertible carseat (w/integrated 5-pt. harness), and into a booster seat that uses the factory shoulder harnesses in my YJ. My younger daughter will still be in her carseat for a while.
Craig
Old 05-18-2005, 02:52 AM   #17 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
although the seatbelts are an issue I think the seat itself is more of an issue - how are you going to get a 5 point to work with the booster? BTW there are boosters with 5 point harnesses in them, my wife insists on it for our kid.
This Space for rent!
Brandon is offline   Reply With Quote Quick reply to this message
Old 05-18-2005, 05:26 AM   #18 (permalink)
Member # 4321
Send a message via ICQ to DEnd Send a message via AIM to DEnd Send a message via MSN to DEnd Send a message via Yahoo to DEnd
The term is D.O.T. Compliant. The D.O.T. doesn't approve anything excepts rules. Harnesses would pass with flying colors If they were tested, but a lot of manufacturers don't want the liability issues that could arrise due to improper mounting. At least thats what I was told by Bill Simpson years ago... I think thats his name anyway I was like 13-14 at the time...
Lame Sig Line
DEnd is offline   Reply With Quote Quick reply to this message
Old 05-18-2005, 07:09 AM   #19 (permalink)
Member # 2769
Originally Posted by currupt4130
... i usually just wear my lapbelt and let my factory 3pt hang on my cage
Oh, now that's really smart.
Jaffer is offline   Reply With Quote Quick reply to this message
Old 05-18-2005, 08:43 AM   #20 (permalink)
Member # 24793
I have run the schroth auto lock for years now and love them. They act like a regular shoulder belt leting you be able to reach the dash and lock when you need them to. I also mounted a switch on the side of both seats. with the flick of a switch the fully lock and become a locked harness. I run a junior prp seat in the back with a Jr. dragster 5 point harness for the kid. Way better than a car seat.
Kory
Is exactly 35 miles from the hammers
EMC car# 4540 Co driver
RockJeep92504 is offline   Reply With Quote Quick reply to this message
Old 05-18-2005, 11:20 AM   #21 (permalink)
Member # 31947
Craig
AFAIK, the rear of CJ-7s came with only lap belts and lap belt should not be used for booster seats, it is not safe! In Indiana there is a new law taking affect later this year and all children under 8 have to be in booster seats, but there is an exemtion for vehicles with stock rear lap belts. I would install lap belts to make the CJ-8 as close to factory spec as possible (referring to the CJ-7) and try to convince the inspector that the harness is for off road, or add it later, and I would mount the harness so she sat on the bench, not in a booster, even off road, and use a 4 point harness (I don't think a 5-point would work with the fold-and-tumble. The alternative it to install a 3-point seat/shoulder belt and use the booster, and I don't think the inspector will have any problems with that arrangement.
EDIT: assuming the harness is sized for a child that is.
84 CJ-8, 99 XJ
84kludge is offline   Reply With Quote Quick reply to this message
Old 06-02-2005, 01:46 PM   #22 (permalink)
Member # 39080
Dj safety belts are DOT approved.
offroadering is offline   Reply With Quote Quick reply to this message
