wiring up a 350 tbi - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2005, 08:08 AM   #1 (permalink)
Member # 24322
wiring up a 350 tbi
If someone could enlighten me on how to search this I will gladly delete this post. I can't find what I'm looking for using 4 letters or more. I'm wanting to figure out how to wire up my 350 tbi and computer from an 89 Blazer into my YJ.
Thanks for any help on search thoughts and I'll delete this before it's moved.
Trying to decide which project to build and which one to get rid of.
crazy_cooter56 is offline   Reply With Quote Quick reply to this message
Old 06-07-2005, 09:18 AM   #2 (permalink)
Member # 22310
The best advise I can give you is to just keep searching here and JU has some good info too. When all is said and done, you are only splicing 6 or 7 wires. Keep the 7747 computer and all of the wiring harness under the hood and the wires coming from the computer, under the dash over to the main fuse block and ALDL.
below are a couple of threads that helped me doing this swap into a 5.
enjoy
http://www.pirate4x4.com/forum/showt...re+harness+tbi
http://www.pirate4x4.com/forum/showt...ight=chevy+tbi
http://www.pirate4x4.com/forum/showt...hreadid=226016
dirtbikes987 is offline   Reply With Quote Quick reply to this message
Old 06-07-2005, 01:04 PM   #3 (permalink)
Member # 20423
Here is the list I put together
It wire by wire what you need to make it run.
Plus the link to the diagrams on diy-efi.org
HTH
Bill USN-1
EFI Moderator at http://www.binderplanet.com
Bill usn-1 is offline   Reply With Quote Quick reply to this message
Old 06-07-2005, 01:04 PM   #4 (permalink)
Geesh's Avatar
Member # 4787
Send a message via AIM to Geesh
This is Cheesasaurus-Rex, but I'll pass it along.
Here's the Summit web page for the Painless TBI kit. Now if you look, you'll see a hyperlink for the installation instructions in PDF form. What I did is just print that and I am using it with my OE harness first. So, if i don't get it to work, I'll order the real deal $300 is worth my time at first pass
Good luck
wrapped in pleather
Geesh is offline   Reply With Quote Quick reply to this message
Old 06-07-2005, 03:20 PM   #5 (permalink)
350TBI's Avatar
Member # 46327
What Geesh said................................The painless kit is great I tried to do it by splicing and soldering. What a waste of time man. I woun dup moounting my ECM under the dash above the Glove box..........
1970 (what's left of it) CJ5 SBC 350 TBI (Stock); 4L60 Dana 300 4:1.....under construction.
350TBI is offline   Reply With Quote Quick reply to this message
Old 06-07-2005, 03:46 PM   #6 (permalink)
Hosejockey's Avatar
Member # 26577
www.affordablefuelinjection.com
or something like that
Hosejockey is offline   Reply With Quote Quick reply to this message
Old 06-07-2005, 03:57 PM   #7 (permalink)
Hosejockey's Avatar
Member # 26577
here i found emm
http://www.pirate4x4.com/forum/showthread.php?t=291426
Old 06-07-2005, 09:52 PM   #8 (permalink)
Hijumper's Avatar
Member # 36803
I'm getting my ECM modified and a harness from AFI for a 4.3 TBI conversion soon. Will post on their quality and service when done.
[FONT=Arial]90YJ 4.3TBI OX's 33's .....it works for me[/FONT]
[QUOTE]looks like she chased a fart through a bag of nails.[/QUOTE]
Hijumper is offline   Reply With Quote Quick reply to this message
Old 06-12-2005, 06:29 AM   #9 (permalink)
Member # 24322
Thank you for the help fellas, I appreciate it.
Old 06-12-2005, 07:49 AM   #10 (permalink)
Member # 1999
Send a message via ICQ to jeeplvr
I am using the AFI harness and chip on my buggy and it works perfect so far. Quality is top notch and so is the service, at least in my experience.
{Gramma from Squidbillies} Lets put coughdrops in our buttholes and play viddy games!
jeeplvr is offline   Reply With Quote Quick reply to this message
Old 06-12-2005, 01:21 PM   #11 (permalink)
lqCJ5's Avatar
Member # 31703
I'm running AFI on my scrambler , top notch . Harness & instructions made for a very easy install
81 CJ8 350 sbc,tbi ,TH400 ,4:1 twin stick 300, 60 frt w/Longfields, 14b rear, 40" MTR's
lqCJ5 is offline   Reply With Quote Quick reply to this message
Old 06-13-2005, 02:13 PM   #12 (permalink)
Hijumper's Avatar
Member # 36803
Thats good to know, thanks for the info. This is my first engine swap - I'm sweating bullets. All of my AA junk arrived today, just waiting on AFI now
Old 06-13-2005, 07:26 PM   #13 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
im going to have to read this later when I want to do mine.
Current build-2002 Chevy truck buggy, 06 front clip tube-coilovers,bypasses-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
2006 dodge 3500 dually tow rig
1967 chevy K10, d60 14bff detroit, 37 mtrs, lq4, sm465, np205
jays68yak is offline   Reply With Quote Quick reply to this message
Old 06-13-2005, 10:05 PM   #14 (permalink)
Member # 23394
I hate to be the bearer of bad news, but i have not had much luck with affordable fuel injection.
Dont get me wrong, Norm is a nice guy, but it took forever (3 months) to get my harness, i guess they were out of connectors, some of the connectors didnt plug in right, and the both chips he burned for me didnt work at all. Took me quite a while to figure out what was going on. The harness delayed my project for a long while. Ended up costing me a lot of money in the end that i thought was unnecessary. Im not happy with the product and will not refer anyone there.
My advice: Go to your local library and tell them you need a wiring schematic for the '89 blazer. They should be able to help you out.
'02 CCSB D-Max
'06 Chevy 1500 Crew Cab
DanTheMan is offline   Reply With Quote Quick reply to this message
Old 06-14-2005, 11:16 AM   #15 (permalink)
Member # 42085
I swapped a 95 350 TBI into my 93 YJ. I knew nothing about them at the time, but have picked up things as I went along. I just used the factory 350 harness and put the Chevy fuse block under the hood and also kept the Jeep one as well. All I did was run one wire from the ignition (hot on run and start) to the 350 harness to power everything up. I also ran power from the chevy fuse block to a chevy fuel pump that I put in place of the Jeep one in the tank. Adapted the Jeep temp and oil pressure sending units into the motor so those gauges were still functional. That was it.
HeyZeus is offline   Reply With Quote Quick reply to this message
