Member # 45631
aussie locker
PLEASE DONT BUMP THIS TO THE NOB SECTION I WANT A REPLY FROM AUSSIE HIMSELF!!!!
Tonight i got a call from a friend. He got your lockers front and rear for a 95yj. The lockers were for a d35 rear and a d30 front (dont give me shit about the stock turds it is not my jeeo LOL). I got the call because i have installed a few lockrights, track locks, spider gears and such in my day. It was easy enough to install (so i thought). We started with the rear. I left out the thrust washers because the locker would not fit with them on. I never used them on any other locker i had installed. We tried your spin one tire forward till it starts to move the shaft (in gear) then spin the other backwards. we could not get it to let go. I told him to back it up 5 feet to see if it just needed to settle. That broke all 4 shear pins!! I know i put it on right. It would not fit on with the thrust washers. I could get it to fit with one washer BUT that would throw off the center shaft making the locker break free to one side more easy than the other. The pins and springs that came with it were the same for the front and rear. SHIT!!! this thing aint even mine now i am out some loot for trying to help a friend with an easy install . I know i didnt mix them up its the XD-13530 rear (with shaft)and XD-13027 front without shaft. Plus the rear has the slots for those damned c-clips. WHY DID IT HAVE SO MUCH PLAY IN THE MAIN SHAFT TO THE POINT THE 4 SPRINGS TOOK ALL THE FORCE AND SNAPPED IN 5 FEET? Do you sell rebuild kits? it did no harm to the locker itself. It still looks brand new. When clearanced right do the 4 pins with the nipples that go into the springs set into the other peice, or do they ride above it? I have spent 8 hours scratching my head! It should have taken 3 to do front and rear! If i dont figure this out in 24 hours i am going to throw his spider gears back in and let him find someone with a bigger brain than me! I have never had a problem putting on any other locker!
Member # 49793
You might want to post your problem here.. It's aussielocker thread in "> Vendors Showcase > Axles/Tires/Wheels" but don't expect a reply on 4th of July weekend!
/forum/axles-tires-wheels/251180-aussie-lockers-stock.html I'll be interested in seeing how they handle this, cus I'm about to put lockers in my ZJ. Good Luck! |
#3 (permalink) | |
Pigs Fly
Yours IS in a D35 though, so it's possible that the housing and/or carrier might be tweaked enough to screw it up.
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 |
Member # 45631
Yeah it will not fit with the thrust washers. I did everything but hit it with a hammer to try to get it in. I used grease, then dry, then switch sides, then change the parts around, and then repeated it all!!
Member # 19383
We are working with the vehicle owner today to set up a conference call on what is causing this installation problem. We responded to the customers email this morning at 2:00AM and got Australian engineernig involved. Once we work through the issues and come up with a resolution we will certainly report here what we found. We apologize that Swamper-Bob and the customer had such a frustrating installation experience as that is not the norm with the many thousands of Aussie Lockers installed to-date.
Member # 45631
WOW! this guy is good! I just got to my friends house. Aussie had already emailed him like 6 times with tec support. I am sure we will get this worked out and my dumb ass prob put something in backwards. Either way he was jonny on the spot with some help A+.
#8 (permalink) | |
Member # 6920
Member # 45631
Well, we got the rear locker in(with the thrust washers) in a couple of hours. It was a very tight fit. It pays to work on jeeps before dark so you can see what your doing. It works perfectly as you said it would with a smooth un-lock around corners. We used the hill on the curb to get a tire off the ground in 2-hi and it stayed locked. I will let him drive it for a while. Then give me some feedback in a few weeks. I broke my trac-lock (took the pins out) on the highway because my swampers had a leak. i had 4 psi in the driver and 21psi in the pas side and didnt know it(sx's have no sidewall flex). For now i just put the stock spider gears back in it. I may end up with an aussie later on because of the help we got. His thrust washer's were thicker than other years of wranglers that i have seen, and that is what caused us the prob. It works perfect now. This is a very smooth locker in my opinion. thanks again!!!!!!!!!
#10 (permalink) | |
Member # 49909
#12 (permalink) |
ZEUS of the JUICE!
Member # 22923
My mind is made up - I am putting aussie lockers in the TJ
until i get a built HP44 up front and gears F/R...I have lockrite experience but I support the underdogs and good cunstomer service vendors
#13 (permalink) | |
-Nate |
#14 (permalink) |
Member # 24322
Glad to hear that they are such stand up folks. I've been considering giving them a try this might influence me that little extra. I would've before if it hadn't been for the backorder months out on my 44 locker.
Trying to decide which project to build and which one to get rid of. |
#15 (permalink) | |
Member # 7163
