Dana 44 SOA high steer arm problems?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2005, 08:06 PM   #1 (permalink)
Member # 21877
Send a message via Yahoo to joeycj
I just did a SOA, Dana 44 conversition on my CJ., with High steer crossover steering. My problem is, the High steer arm on the Passenger side is hitting the tire... Are there High steer arms that are curved a bit to eliminate this?
joeycj is offline   Reply With Quote
Old 08-07-2005, 09:05 PM   #2 (permalink)
withamc's Avatar
Member # 1757
What size rim and backspacing are you running? Yes there are arms that are offset to the center - I have Tri County Gear arms that are set slightly to the center, but too much and you screw up your ackerman angle.
withamc is offline   Reply With Quote
Old 08-07-2005, 09:12 PM   #3 (permalink)
Member # 21877
Thanks, im using stock CJ backspacing... 3 1/2 - 4", and 15 x 8 wheels, with 35".... THe arms I have now are just about perpendicular to the axle tubes, they need to be turned in a bit, I think
Old 08-08-2005, 08:33 AM   #4 (permalink)
Budd's Avatar
Member # 28368
What arms are you using - the Blue Torch ones have a slight angle in them and clear H1's with a 1.5" spacer. Total backspacing is now approximatley 5.75" (7.25 - 1.5).
'68 Jeepster, GN powered
Budd is offline   Reply With Quote
Old 08-08-2005, 11:58 AM   #5 (permalink)
Damage, Inc.'s Avatar
Member # 20298
Call PartsMike...(www.partsmikeparts.com)...he has the arms that clear. That's what I have on my D44 SOA. Call him and talk to him...he's VERY friendly and will answer any question you have.
I didn't read what he said, but he's right. - BHC
Damage, Inc. is offline   Reply With Quote
Old 08-08-2005, 06:45 PM   #6 (permalink)
350TBI's Avatar
Member # 46327
So there I was..........................I used the frickin Poison Spyder Arms and Spacers with no probs 37 MTR on 15 Allied Bead Locks....Hope it helps dude!!!!!!!!!!!!!
1970 (what's left of it) CJ5 SBC 350 TBI (Stock); 4L60 Dana 300 4:1.....under construction.
350TBI is offline   Reply With Quote
Old 08-08-2005, 08:40 PM   #7 (permalink)
Member # 21815
Extreme Gear arms, 1 1/2" Poison Spider spacers, 10" Weld rms with 3.75" of backspace running 37" MTR's. Easy 2 1/4" of clearance, so combo would work even without the spacers. Good luck.
resqme is offline   Reply With Quote
Old 08-09-2005, 10:30 AM   #8 (permalink)
BlueTorch's Avatar
Member # 14529
If the passenger side arm is the hitting it could be due to where the holes where drilled and tapped in the knuckle. Since you already have the holes drilled and tapped you would have to go to a dfferent arm design or a wheel spacer like some of the others have mentioned.
if I can help let me know.
Thanks
Dan
Blue Torch FabWorks, Inc.
205-521-7333
www.BlueTorchFab.com
"Like" us on Facebook!
www.facebook.com/bluetorchfab
BlueTorch is offline   Reply With Quote
Old 08-10-2005, 06:09 PM   #9 (permalink)
Member # 21877
Hey guys, thanks for the info.
Dan, Im startin to think the holes were not drilled in the right spot. Is there a standard, as to where these holes are to be e drilled and tapped? My d44's were custom made by drivetrain direct. With the arms bolted on, they are almost perpendicular to the axle tubes, with tires pointed staight ahead.
It only hits on passenger side. High steer studs are in identical locations on both sides of axle. Is there any one that makes offset arms, that turn in a bit?
When talking to PARTS MIKE, he says I should switch over to the his "T-steering" set up, I would be using the shorter arms, with one hole on each arm. and there should be no clearance issues. But I was hoping to keep the factory tie rod/ drag link set up that is used on the CJ's.
Old 08-14-2005, 07:35 AM   #10 (permalink)
Member # 21877
ttt
Old 08-14-2005, 09:17 AM   #11 (permalink)
withamc's Avatar
Member # 1757
Like I said earlier, Tri County Gear makes the arm that I use and it does angle in slightly. D44 with Dodge knuckles, 15 X 8 wheels with 3.5" BS, I probably have 1" clearance.
You say you want to retain the stock CJ setup. If you're going to a high steer setup, why wouldn't you take the opportunity to replace the flimsy CJ setup with some stout 1 ton parts and eliminate another point of failure? Billavista has a good write-up that describes how to utilize readily available GM 1 ton TREs. I took this info and tapped some 1.25"/.25" wall DOM tube for a pretty indestructible front steering setup.
Old 08-14-2005, 06:42 PM   #12 (permalink)
Member # 21877
Thanks for the tip "withamc", ill check into it... I see partsmike has a T-steering set up. May be what your speaking of?
Old 08-14-2005, 07:09 PM   #13 (permalink)
withamc's Avatar
Member # 1757
I have no idea what Parts Mike sells. Read this for ideas.
http://www.pirate4x4.com/tech/billav...ngresearch.htm
