Jeep Liberty Turbo Diesel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-26-2005, 06:51 AM   #1 (permalink)
Member # 22064
In my internet cruisings I came across this photo of the hind end of a 2005
Jeep Liberty 2.8L Turbo Diesel. When placed next to the bellhousing from a Dakota 3.9L V6 AX15 bellhousing, the bolt patterns look suspiciously similar! (That is, the same as the Chrysler Small Block pattern) Hmmm....
Greg
Greg55_99 is offline   Reply With Quote Quick reply to this message
Old 08-26-2005, 10:13 AM   #2 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
Innnnnteresting.....Any idea on weight?
JeffsJeep04 is offline   Reply With Quote Quick reply to this message
Old 08-26-2005, 10:24 AM   #3 (permalink)
Member # 20092
double hmmm.
It sure looks the same to me.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 08-26-2005, 01:18 PM   #4 (permalink)
YJ4RoX's Avatar
Member # 1930
good find, definitely looks the same to me. 2.8 turbo diesel, ax15, np203/d300 would be a nice little set up. Too bad they will be major coin.
YJ4RoX is online now   Reply With Quote Quick reply to this message
Old 08-26-2005, 02:31 PM   #5 (permalink)
Member # 9994
doesn't the Dakota BH had a bolt hole at 12:00, but the engine doesn't?
also, the starter bolt on the engine is at about 7:00 from the BH bolt hole and on the BH is is around 8:00.
i think they are close, but not exactly the same...someone creative might be able to make it work!
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
jeepnmatt is offline   Reply With Quote Quick reply to this message
Old 08-26-2005, 05:34 PM   #6 (permalink)
Member # 20339
I can't say I'm much of a gearhead, but how many engines have 8 bolts on the flex plate?
As far as the 12:00 bolt, if you only have one bolt that doesn't line up. Your doing good IMO.
I got nothing
bigcamojeep is offline   Reply With Quote Quick reply to this message
Old 08-26-2005, 10:26 PM   #7 (permalink)
Member # 22064
Looks REAL close to me. Wish I could verify this.
Greg
http://cgi.ebay.com/ebaymotors/05-Je...spagenameZWDVW
Old 08-27-2005, 07:48 AM   #8 (permalink)
jpnjim's Avatar
Member # 22209
With eyes like that, you guys should work for NASA
A couple of the bolt spacings look right (like above the starter), but alot of the others are iffy.
Would be nice if it used a patturn common to the US though.
Keeper of hEEPs
jpnjim is offline   Reply With Quote Quick reply to this message
Old 08-27-2005, 07:52 AM   #9 (permalink)
nights end here
FlexCJ5's Avatar
Member # 35217
The august issue of JP has a whole write up on this swap.
I build AK-47's in my living room and have a huge cock, my .22's compensate for my enormous manhood.
James Firearm and Palmetto State Defense
01/03 and 07/SOT
FlexCJ5 is offline   Reply With Quote Quick reply to this message
Old 08-27-2005, 02:39 PM   #10 (permalink)
yuppiedood's Avatar
Member # 23841
and spike's truck show was showing how you can make bio diesel fuel at your house for .70/gal....
the swap could pay for itself.
[FONT=Comic Sans MS]"praise the jeep lurkers, because they are few and the noobs are many."[/FONT]<p>
[FONT=Comic Sans MS]"the beauty of my jeep is it's not a beauty"[/FONT]
yuppiedood is offline   Reply With Quote Quick reply to this message
Old 08-29-2005, 11:27 AM   #11 (permalink)
Member # 52361
That would be a sweet swap. Will the oil pan clear the frame and crossmember. What about taking the motor/trans/tcase from the liberty? I'd buy a wrecked liberty so you get everything. I'm putting a cummins 12v and 4spd auto from a 91 dodge into my 75 F250 4x4, and I am constantly going into the backyard to pull some dinky part that would cost me $50 at a dealer or a day in a junkyard. Check for an insurance salvage auction near you where you could pick up a deal, or ask your insurance agent to put you in touch with their total loss division.
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 08-29-2005, 11:27 AM   #12 (permalink)
Member # 52361
That would be a sweet swap. Will the oil pan clear the frame and crossmember? What about taking the motor/trans/tcase from the liberty? I'd buy a wrecked liberty so you get everything. I'm putting a cummins 12v and 4spd auto from a 91 dodge into my 75 F250 4x4, and I am constantly going into the backyard to pull some dinky part that would cost me $50 at a dealer or a day in a junkyard. Check for an insurance salvage auction near you where you could pick up a deal, or ask your insurance agent to put you in touch with their total loss division.
Old 08-29-2005, 03:29 PM   #13 (permalink)
ddestruel's Avatar
Member # 20999
Things that were intended for lives of abuse LOL
Hemi's. 426, 354, 331, 392
cummins 4bt 6bt
IIRC Perkins
Duetz
Some John Deers
old ford Tractor 4cyls had 8 bolts in some of thier stuff cant remember if internationals had 8 bolts i thought for some reason the 345, 392 and some of the bigger gasser industrial motors came with 8 bolts including the 7.3 and 6.9 but i could bre wrong on those
there are some others i just cant think of em all not overly common but you'll see it from time to time
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA,
and some
I miss my
Support Frank the Tank
ddestruel is offline   Reply With Quote Quick reply to this message
Old 09-23-2005, 10:23 AM   #14 (permalink)
Member # 22064
Confirmed!
Message from John Fleck:
"Since we make the transmissions, I can verify they are the same bolt pattern. (The same case bolts to the CRD (Diesel) as the 3.7, 4.7, and 5.7L. All of these are the same bell housing pattern as the 5.2 and 5.9L Magnums and LA engines. The CRD engine is made in Italy by a subsidiary but it has Chrysler pattern."
John Fleck
Kokomo, IN - DaimlerChrysler Engineer, Indiana Trans. Plant
