Member # 6647
SOA front axle traction bar ideas?
I need to come up with a way to eliminate the axle wrap in the front of my SOA YJ. My driveshaft is setup with 7" of slip and has plenty of spline engagement when flexed on a ramp but on my first shakedown run the driveshaft pulled apart when climbing under throttle due to axle wrap. Rather than simply buy a longer-travel driveshaft to band-aid fix the problem I would prefer to fix it once and for all by eliminating the cause, axle wrap. My front suspension is setup with BSD 4200 (YJ 2.5" lift) springs with the military wrap cut off level with the spring eye bolts due to clearance issues. My front springs are setup tight to the frame and level from spring eye to spring eye. The shackle rests back from verticle, I can't remember exactly how much. I've attached a few pictures from the buildup to show how everything is setup and what kind of room I have to work with.
![]() ![]() ![]() ![]() ![]() I first considered mounting links from the u-bolt plates to the front spring hanger. This would be the quick and easy option but I really don't have room at the front spring hanger to make this work. My next option is a traction bar mounted off the back of the axle but I have two concerns with such a setup: 1. Will a ladder bar type traction bar funtion properly on the shackle side of the spring? 2. Would a cantilever mount for the shackle end of the traction bar hold up long term? As you can see I've already notched the frame in the area where the cantilever mount would be located. Does anyone have a proven setup they care to share? I've searched off and on for a couple days and there really isn't much info out there for front axle wrap control. Last edited by Wes in TN; 10-11-2005 at 01:28 PM. |
Member # 27999
The only one I have actually ever seen a picture of was the one on the front of Cappa's big jeep truck on Rockwell's and 49" Iroks. It goes from the axle forward to the front of the rig. I would be interested in seeing some ideas on this also as I might build one also.
4-seater buggy |
Member # 20092
Pm bigdude.
He's got one on the front of his wrangler that seems to work well.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074. |
Member # 31688
Depending on how much room you have, hi steer, frame, etc. you might be able to do something like this in the front. The flaws of this imperfect set up have already been discussed, this is not a "perfect" antiwrap device but it works well enough for me and my needs. Here's some booty fab for ya
I run this in back and it works alright, copied Durhams set up and then incorporated the bump stops into the towers to kill two birds with one stone. I don't have a lot of room for an antiwrap in the middle. I twisted it up both with and without these bars in and it had no effect on flex. I have bent the rear springs (stock YJ's) but others have run similar set ups without tweaking them (Hybridpos I believe) I think Geberhard was going to run a cable instead of bars, that would probably work better in front for clearances. Search for "anti wrap for under $10" Sorry, I accidently deleted all these thread subscriptions so no links. Last edited by fubar73cj5; 11-20-2005 at 06:35 PM. |
Member # 46653
I just put a x member frum moter mount to moter mount then ran a limet strap to the back side of the housing as low as you can get it. and it worked perf. keeps the axel from walking a way in climes and it will not let the housing roll ether.
#11 (permalink) | |
Member # 17777
Holy Tire Pick Batman!!!
Maybe it's just me, or the picture is deceiving, but I wouldn't be proud of my vehicle doing that.
#14 (permalink) | |
Member # 6647
I can't make out much from the pictures, are you mounting them from x-members or cantilevered off of the frame? |
#15 (permalink) | |
Member # 14488
#16 (permalink) | |
Member # 14004
1. Yes, but the shackle should be at least as long and at the same angle as the spring shackles. 2. Front axles are generally under less load than rear axles so you might get away with it. I would limit the width of the bracket to six inches.
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's 87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's |
#18 (permalink) |
Member # 6647
Some great ideas so far. I believe I am going to try and fit a traction bar coming off the rear of the axle. Hopefully I can find room for it stuffed between the engine and frame.
#19 (permalink) | |
Member # 4830
Neither does the fact that he has the strap hooked to the worst possible spot for towing, and if it breaks its going right through his head. ![]() Blake |
#20 (permalink) |
WFTW Part Deux
Member # 19355
I use a more traditional style traction bar on the front.
Heims at axle, johny joint at crossmember. No impact on flex and no issues with 4-to-1, 6.17's and 42's. Make sure the cross member is beefy. |
#21 (permalink) |
Moderator
Member # 5861
What about adding leafs to the pack? My front wrap was gone with the home brewed pack and no impact to flex, over 8 leafs and still flexes very well:
#22 (permalink) |
Member # 1636
I was going to make an upper link from my passengers inner framerail where insayn's is to the axle. then I started thinking which always gets me in trouble, and figured I'd add the two lowers and get rid of the problems (the leaf springs themselves) all together.
now accepting donations |
