ax15 trans with a np205 t-case??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-09-2005, 10:05 PM   #1 (permalink)
94xjkyle's Avatar
Member # 55800
i have a jeep with the aw4/ax15 tranny and i have a np205 sitting in my gerage along with the front axle to go with it (pas side drop), how do i get the np205 to mate with the ax15 trans?
94xjkyle is offline   Reply With Quote
Old 11-09-2005, 11:07 PM   #2 (permalink)
Quit changin my shit
Otto Man's Avatar
Member # 18977
Send a message via AIM to Otto Man
You bolt them together. You could weld them if you wanted to, but that may make it a tad more difficult to separate them. However, most non-fucksticks choose to search and see what their options are.
Originally Posted by Sully
It's a respect issue. Just because you can, doesn't mean you should.
Would you tell your Grandmother to go suck a big black cock, just because you could?
Otto Man is offline   Reply With Quote
Old 11-10-2005, 06:45 AM   #3 (permalink)
Member # 15049
Really though, you need a high nickle rod when you weld them, don't forget the aluminum additive for the AX-15 portion.
1986 K30
sw99 is offline   Reply With Quote
Old 11-10-2005, 07:03 PM   #4 (permalink)
94xjkyle's Avatar
Member # 55800
i tried to search and all i found was more fucksticks being told to search
Old 11-11-2005, 11:03 AM   #5 (permalink)
Member # 5344
Not sure if the spline are the same? If not I'm sure Advanced Adaptors could help ya out
If you don't learn from History, then you are doomed to repeat it
Mohadeab is offline   Reply With Quote
