Member # 34271
converting waggy 6 lug to 5x4.5
im hoping on converting my waggy d44 front to 5x4.5 but im not too sure on my options.
from searching ive found out that i can use some 70's dodge but they are aparently crap and im not interested in that. basically i will be keeping the d44 rear in my jeep so i am hoping to match the pattern and keep my rims, or will it be easier and cheaper just to make the rear 6 lug and get some rims? spacers are the option i would prefer to go but i havnt found any to go from 6 to 5x4.5 or from 5x4.5 to 6. |
Member # 1796
when did 5 on 4.5" become hardcore??
89 YJ with Parts Scott Dark Horse Customs 406-587-2944 Dark Horse Customs Facebook Page Dark Horse Customs Website |
Member # 46236
Convert the front to 5 on 5.5 and get dual bolt pattern alloys to match.
FTH-3 Chassis, Tuned 5.3 w/4l60E, Stak, Built 60's. 39" maddogs on 20" Trailreadys...08 Dodge Cummins, 68RFE, EDGE, mp8, Deletes ect...DYNO-497hp/1020TQ |
#6 (permalink) | ||
Member # 1635
Looks like your unhappy with your findings, guess you can't do it. Just get some new/used wheels, and this has been covered many times, try the search above.
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html |
Member # 31780
you could just spend the extra $100 or so and get a rear waggy d44. or you could get cromos that are 6 lug for your exsisting d44.
88YJ, d60 with some goodies&14bolt,atlas,111"wb,40"creepies,some other stuff and 6 angry hampsters under the hood!:D tow rig: 07.5 6.7l dodge 2500 Dixon 4Wheelers Build it, Break it,Fix it, Repeat! |
#8 (permalink) | |
Member # 34271
and i havnt checked or anything, but im assuming waggy shafts wont fit a tj? ( havnt looked at the length or anything, just popped into my head) |
Member # 44544
wait did you realy just ask if a waggy dana 44 axle shaft would fit in a stock jeep wrangler front axle? no no no no no no no no no and no there is know way at all even if there was a way to get the shaft to fit in the tube it would still be to long so no get a set of steel wheels for $100 and a new rear axle for $100 and be done and have a stronger drive train
just call superior and order the rear shafts with both 5 on 4.5 and 5 on 5.5 patterns drilled into them. redrill the rear drums to 5 on 5.5 (very easy even with a hand drill) and then convert the waggy axle to 5 on 5.5
~~Elusive~~ I just wanna wheel. |
#11 (permalink) | |
Member # 34271
no i didnt ask that, i was asking about a rear waggy d44 and a tj rear d44 as for the shafts from superior, couldnt i just order them 6 lug and save the hassle of converting the front to 5x5.5? |
#12 (permalink) | |
Go 5 on 5.5 for the front and get adapters/spacers for the rear. Or sell your rear TJ 44 for $1200 (Someone on JU will pay that) and build a Waggy 44 for the rear with RE brackets. Then most of your axle parts OEM/Aftermarket will be off the shelf Waggy items easy for replacement.
I Like Boobs Last edited by joe_and_jeep; 11-24-2005 at 07:50 PM. |
#13 (permalink) | |
Big Meanie
Member # 5859
Ka 'aina uluwehi, ko kakou
kuleana. - The lush life-giving land, our personal responsibility. Ventura County Axle Snappers - Nevada County Chapter |
#14 (permalink) |
Member # 31780
what i ment was why not get some 6 lug shafts made for the rear from someone like dutchmen or moser and then find a waggy d44 in the junk yard and take the brakes off of it. why go through all the hassel of converting both to 5 on 5.5?
#15 (permalink) |
lets review.
$275 gets you new chromoly shafts for the rear with both bolt patterns $100 in junk yard parts gets you 5 on 5.5 in the front though I have no idea why anyone would ever do this rather than just start with a high pinion 5 on 5.5 ford axle.
#16 (permalink) | |
Member # 2790
That would be the easiest and smartest..
Russ hy_desert_4wheeler 46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline- |
#17 (permalink) |
Member # 26573
Just put a HP30 in it out of an XJ. The Waggy 44 is only marginally stronger and you don't have to weld any brackets on the HP30 and the lug pattern will be the same. If you are going to the trouble of welding brackets on at least put a Ford HP44 in it.
http://www.crazybabyclothing.com/cool-baby-onesies-c-24.html |
#18 (permalink) | |
Member # 34271
