J series possabilities
I was wondering what i should look out for as a possible problem with a J series P/U. There is one for sale cheap down the street from me that looks to be relatively stock. So is there anything significant that I should be looking for/looking out for? Any recurring problems that they had other than the standards? i don't know the year yet because it was locked up and I couldn't get a good look at it driving by at 40 mph. But it was a long be not a short. Any help would be appreciated. What is the most that you would spend on a used J series truck?
Member # 6234
no more than 3 grand, and that's if it's in near perfect shape (not to brag, but mine is in great shape and it's an 85) for a recent model.
things to look out for... rust on the frame rails, make damn sure the electrical system is in good shape (my old wagoneer used to catch on fire), general body damage, missing trim pieces, non-leaking heads/seals/gaskets/pumps/parts (this is a big issue with any jeep older than 10 years, of course) other than that... FSJs are beasts. i can take my J10 places that my 4 banger YJ couldn't touch.
85 W150, 94 YJ, 86 Bronco |
Willy,
You do have a sweet ass truck. Is that toggle on the bed original or did you do it your self? Yours was one of the only trucks I found that looked decent when I did a search. (Yeah I'm new and I know what that button is) Any way I know about the standard jeep problems to look for. RUST, leaking heads and shiat, btu is there anything model specific. Also is there any "holy grail" year model that has all the shiat everyone is looking for. I.E. as far as components is there a best year model? |
Member # 5654
I dont know, it depends on the owner. J10s are a funny creature, seen good examples go for almost 10K, and other good ones go for 3K!? I have one, and love it. What can u say, decent full size axles (even the AMC 20 has a nodular pumkin, thicker tubes, and one piece axles from the factory on a FSJ), on a 3/4 truck that has TONS o room for tires, and has a flexy stock suspension. It has crossover from the factory as well, and hardly any PUs had it back then. I have one that is sprung over in front on stock waggy front leafs, and rustys rears with blocks and it wheels AWESOME. It is a bit of along vehicle though, so try and get a shortbed. I also am not a big fan of the quadratrack crap, so try for a part time truck.
#5 (permalink) | ||
Member # 6234
******************* well, you might or might know bout the 83-84s, but they had vaccuum front ends... avoid those if you can. you can always just swap 'em out tho and plug the line. hmmmm golden years huh? well of course the god of J trucks IMO would be a 77-78 J20 (77 was the first year they got a decent ignition) with a 401/t18a/d20 combo. 77/78/79 were actually the best years for jeep production, so they're more common than you might think. model specific? not that i can think of. J trucks are pretty solid just because they're so utilitarian. qtrac gets a bad rap just cuz no one ever took care of theirs... when they're properly lubed and cared for, they're great xcases. jeep used to use them for desert racing
#6 (permalink) | ||
Member # 5654
#8 (permalink) | |
Member # 6234
don't forget that J20s never used vaccuum front axles or the amc20 rear. i think they stopped putting t18s in them around 83-84 tho... all you could get was the tf727
Okay,
DANFSJ question, What is the diff between a J10 and a J20? I know the whole story back and front about CJ's. But I'm just delving into the fullsize realm. Help a dambass newbie out here. Is one better than the other. Oh yeah an yes the suit is on so away.
Member # 6234
J10 is a 1/2 ton truck (even tho technically the weight rating is a 3/4 ton) available in 119" WB short bed and 131" WB long bed
J20 is a 3/4 ton truck available in 131" WB long bed only J10 has either a d44 rear or AMC20 rear - six lug J20 has a d60 rear (30 spline full float) - 8 lug J20 rides a bit higher than the J10 all i can think of right now
