Rubicon 4.10 ring and pinion in cj dana 44 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-20-2005, 06:16 PM   #1 (permalink)
Member # 18816
I am looking at putting a set of free rubicon 4.10 r and p into my 30 spline jeep rear 44. I would think it is the same setup. I have heard the rubicon uses a 35 housing with 44 axles and r/p? Thought there maybe something else you guys might know. I did search to no avail. Thanks ahead of time..
I think I need my medication....
74 CJ5
macdaddy is offline   Reply With Quote
Old 12-20-2005, 10:50 PM   #2 (permalink)
Redmist's Avatar
Member # 43646
The Rubicon Housing front and rear is a 44 housing. Its the tubes and outers that are 30's But only in the front.
I think the Rubi R&P is a bit thicker or something then a standard 44. Do not go on what I said though.
Redmist is offline   Reply With Quote
Old 12-21-2005, 04:16 AM   #3 (permalink)
Mad Scientist
williamj's Avatar
Member # 35484
I am not 100% sure but it should work as long as you are using a carrier for the lower gear sets(3.92 and below I belive).
williamj is offline   Reply With Quote
Old 12-21-2005, 09:06 AM   #4 (permalink)
Member # 18816
Thanks , I will get them in there then to see if it works Appreciate the help...
74 CJ5
Old 12-21-2005, 09:10 AM   #5 (permalink)
Member # 31852
Rubicon 44 4.10 Ring gears are thicker than normal D44 4.10s.
nagal is offline   Reply With Quote
Old 12-21-2005, 09:36 AM   #6 (permalink)
Member # 48895
IIRC the rubicon carrier uses a different size bolt to retain the ring gera than most 44's
aintlifegrand is offline   Reply With Quote
Old 12-21-2005, 06:01 PM   #7 (permalink)
Member # 29571
It works.
rbaer is offline   Reply With Quote
