#26 (permalink) |
Member # 61536
You fucked up. I have the same tank on my tj. In the same location yours is but I sunk it into the floor almost all the way in but 3 inches on the top stick up in the trunk. Take a piece of 1/4 inch steel plate and attach it at the bottom of the frame in the rear flush to it(also makes tank skid), cut out the floor to slide the tank in, use the same mounts you did on the steel plate attached to the bottom of the frame. That way you only lose 3 inches from the floor up of the dimension of the tank. I cant take pics so I cant show you. Also, at the rear above the tail light, mount the filler on the outside, that way you can fill the fuel outside the vehicle and not have to open up the jeep to fill, plus no fuel smell. If you want to get fancy, make a cap for the top of the tank that shows, bolt to the floor, and you will never notice. Fairly simple mod to do, requires almost no fabricating, just a little cutting, drilling, and bolting. Did mine in less than 1 hour. The thought took longer though
Oh yeah, it still works with your rear wheel based stretched for up to 12 inches with a d60, make sure you cut out the floor all the way to the back, I didnt have to remove any of the stock tailgate, 3rd brakelight, locking mechanism at all. pm me if you want more info.
#27 (permalink) |
Member # 36746
Redmist do you have any leaking problems with yours? Mine leaked bad, but again I left off the stock rubber gasket. I just put seal all around mine an I think it fixed the problem. I am probably gonna have to go back in that damn tank to investigate why the fuel pump is not working. My arrow is facing fwd also, that was a typo, so I am not sure what the problem is?
#28 (permalink) | |
Member # 6562
3/4 Ton YJ |
#31 (permalink) |
H Rated
Member # 36099
Redmist....have you had any issues with cracking on the cell mounting tabs from having it suspended in just the four corners? I have just completed the same cell and mounting location and started second guessing the long term effects of not adding a vibration absorbing pad under the center portion of the cell.
#32 (permalink) | |
Member # 70068
In Memory of: '04 Rubi Sunray 9s ....sitting low Now: '04 LJ on Tons, gotta get it lower |
#33 (permalink) |
I will be suspending my cell in a gurdle and not using the welded on tabs at all. I have seen them crack especially when you have each tab going to a different member and stressing the cell.
No one has answered my question about the stock pump in the cell. Are all of you suspending them in the cell without support on the base? I was told this was a big no-no and will cause premature failure of the pump and the reason they are spring loaded is to push them against the bottom of whatever it is sitting in. So...how are all of you supporting the pumps in a too tall cell? And Blue Torch guys how much height does you thread ring add to the pump? Chad |
#34 (permalink) |
Member # 43646
Wow damn this came back from the dead fast!
I don't feel that I "Fucked up" as the cell works fine and I would rather not cut my floor. Thanks for the info though man! I may sink it in at a later date. I did use two bump stops frpm my rear tail gate under the cell. I am going to remove them and use a large mud flap to cover the entire surface area under the cell. I am also going to add straps to the cell and make a box around it that seperates the cab from the cell. I have JUST A LITTLE smell of gas left in the jeep if it sits for a couple of days. It is gone in about 30 seconds from starting the jeep. A plus to the 03 and nere jeeps is that the vent for the hard top over preasure is in the tail gate! So the fumes are pushed out the back of the vehicle instead of having to get to the hard top vents on older models. No cracking so far! |
#35 (permalink) | |
Member # 43646
yoy can take 3 small screws and run then through the expansion track on the pump at its most extended location. This will fix the pickup and make it so it cant come loose. |
#36 (permalink) | |
Member # 43646
damn long time no see phatXJ! Have you seen Daves rig yet? Dynatrac 60/70 Exo 38's.... It works great! |
#37 (permalink) | |
Member # 6562
Your TJ is coming out sweet. I like how you just dove in head first on a practicly brand new rig ![]() I sold the XJ a while back and built up a YJ. I'm about 3/4's of the way though it now. Here's a link to some pics: http://jeepin.net/forum/showpost.php...&postcount=392
3/4 Ton YJ Last edited by PhatXJ; 06-24-2006 at 12:27 AM. |
#38 (permalink) |
Member # 68117
if you havent sold your kilby skid i will buy it from you since i really need one. thanks
brendan mi2bmx@aol.com email me if available |
#41 (permalink) |
Newbie
Member # 84785
Fuel Cell rings
TJKen, please hook me up. I need the rings for a TJ fuel Cell project in the works. Can you help, How much, and where do I send it? Awaiting your reply.
"IF PARTS AIN'T FLYIN, YOU AIN'T TRYIN" |
#42 (permalink) |
Member # 8563
Sent you a PM!
[URL="www.kore4x4customs.com"][SIZE="3"]KORE4x4Customs.com[/SIZE][/URL] [SIZE="3"][COLOR="DarkRed"] [email]Kenneth@KORE4x4Customs.com[/email][/COLOR][/SIZE] [CENTER][SIZE="5"][COLOR="Yellow"][URL="http://www.pirate4x4.com/forum/showthread.php?t=988162"]KORE Defender Chassis...Designed for Speed![/URL][/COLOR][/SIZE][/CENTER] |
#43 (permalink) | |
Run For the Hills
Member # 44531
Anyone else seen anything similar on the fuel gauge? I just installed an iEquis gauge on my fuel cell with a 0-90 ohm sender and the needle is hanging out just below the E. I have about 1/4 tank in the cell.
Check out The Union Creek Journal, a fictional, diary-style chronicle of a Midwestern family's struggle to survive in the aftermath of a global economic collapse. Last edited by Mudinyeri; 07-07-2007 at 01:23 PM. |
#44 (permalink) | |
grumpy ol' dude
Member # 70884
Any pics of where you put the three screws? |
#45 (permalink) | |
Member # 108456
Edit: Found this pic on the internet. You can see where the screws need to go. It's the part right above the metal canister that has a slot in it. There are three of these. http://www.stu-offroad.com/engine/fu...fuelpump-1.jpg Last edited by dannyz14; 05-25-2009 at 08:03 PM. |
#46 (permalink) | |
grumpy ol' dude
Member # 70884
#47 (permalink) |
Member # 108456
There is a small hole in the metal at each arm, this is where the screw needs to go through. Then continue through the plastic. The screw will go through the metal hole and then through the slot in the plastic. Make sure that you use thick enough of a screw that it grabs both the metal and plastic to keep anything from moving/sliding.
#48 (permalink) | |
grumpy ol' dude
Member # 70884
![]() One more question you have an answer to. I'm using the KORE adapter ring. It comes with a gasket. The stock o-ring gasket won't work with the one in the KORE kit so I'm assuming you don't use the stocker. Is this correct? Last edited by -sean-; 05-25-2009 at 08:34 PM. |
#49 (permalink) | |
Member # 108456
