#101 (permalink) |
Member # 69767
I had this same problem, I used some RTV clear silicone and went lightly under the KORE gasket, lightly over the gasket and plugged the vent hole on the factory TJ pump. So far, no more leaking gas.
Hauler: 01 Powerstroke ExCab 6"Stacks 4" Lift Krawler: 97 TJ 5.3 V8 42" Iroks Dana 60's Atlas |
#102 (permalink) | |
Member # 42791
A 99 tj stretched to 106,tubed with some 60's and some red labels, seems to go good. |
#104 (permalink) |
Member # 43646
Yep, ever since I did this, I have always had a "P0455" Gross leak detected code thrown. I clear it and it always comes back. I have dinked with it so much I have pulled my hair out!
Do you guys have a rubber seal on the fuel cell gas cap? Mine is just aluminum. Could it be reading a loose gas cap? |
#106 (permalink) | |
Member # 52637
Don't know why it's throwing it Last edited by jackal_71; 06-24-2009 at 11:54 PM. |
#107 (permalink) |
Member # 21938
we are in the peocess of installing the cell in an 04 rubi. What did you guys do with the charcoal canister and all the crap along with it?
Thank's
northjerseyjeepclub Save tellico #112 [I]origionall posted by entropy I'm so jealous, my penis just left me with a note telling me I'm a loser and he is going to find a cooler guy to hang with...[/I] Quote: [I]Originally Posted by TrojanMan It's on another non-4x4 related site too... jeepsunlimited.com[/I] |
#109 (permalink) |
Member # 72230
Can you tell me which one of the two Evap hard line you tied the vent to. I'm doing the same thing and trying to figure out how to get things hooked up and not throw a code. Nice looking job BTW.
#110 (permalink) | |
grumpy ol' dude
Member # 70884
With my set-up you will get a code, there is no evap system being used. The only way I can eliminate the code is to hook the evap system back in line with the fuel system. BTW, I have been meaning to thank Redmist for this write up... thanks man. ![]() I have had my set-up for a while now, which is pretty much a total copy of Redmist's original set up, and it has worked great. No leaks and no other issues at all. Last edited by -sean-; 07-23-2009 at 06:26 PM. |
#111 (permalink) | |
2012 F150 FX4 EcoBoost - Wanting a built LJ/JKUR |
#112 (permalink) |
Member # 3893
This thread won't die
![]() So, I have everything on the Jeep cut out and ready to go, the cell is in place on my Jeep. I'm ready to cut the cell, the KORE rings, and get this job done. Do stainless bolts need to be used on the lower ring? The ring itself is not stainless after all. I wouldn't think that rust or corrosion would be an issue. I never saw a definite answer on what everyone did as far as the gaskets go. Does the KORE supplied gasket go on the bottom, then the factory on the top? Silicone everything lightly to ensure a good seal?
'97 TJ - D60 Ford Front, D60 E350 rear, build is going slowly... '06 Dodge CTD 4x4 QuadCab |
#113 (permalink) |
Member # 42791
Silicone breaks done when subjected to gas, dont use it or it will leak.Use the rubber seasl and gasket and you should be good to go.
#114 (permalink) |
Member # 3893
Thanks, and I forgot one other question... is there something inherent in the design of the TJ pumps that keeps it fueled when off-camber, or should I be looking at a way to mod the pickup to feed from a pair of Walbros? I realize the factory tank is flat and therefore less likely to be completely starved than this tall tank (when not completely full), but I've NEVER had a fueling problem in the stock setup, even when laying on my side and the tank nowhere near full.
#115 (permalink) | |
#116 (permalink) | |
Member # 1760
-KB |
#118 (permalink) |
Yes yes I know.....I'm in the process of strapping it down. I rarely drive it and when I do its usually no more then 10 miles to and from work. It's about to get 1 tons this winter so I will be fixing that. 2 of my tabs already have cracks running half way through them.
#119 (permalink) | |
Member # 111402
![]() http://pirate4x4.com/forum/showthread.php?t=865500
Proudly Serving: 13B Field Artillery 1-163rd ![]() NalinMFG.com Please become a fan on Facebook! |
#120 (permalink) |
Member # 1172
Anyone put a bladder type fuel cell with the 4.0? Have the 2161 with the KORE ring now and factory fuel pump, but want to change to the bladder cell with a remote pump.
What type of pump will be the most reliable? E2000??? Will the E2000 even work with the factory 4.0???
98 TJ Buggy /forum/jeep-hardcore-tech/647639-axle-suspension-redo-3-link-4link-tru-hi-9-a.html http://www.jak4x4.com 1st place Dirt Riot Coppermines Race Mod Trail class. |
#123 (permalink) |
Member # 127171
Anyone have any idea what size self tapping screw they used on the pump. Over read a ton of write-ups and no one remembers or posts. Will any one work for the most part?
"You never really know a woman until you meet her in court!" |
