nv3550 to dana 300 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2006, 01:59 PM   #1 (permalink)
Member # 66280
nv3550 to dana 300
I am putting a nv3550 tranny in my CJ, looking for some advice on clocking it up with a ring or redrill the tranny
It is a direct bolt on but the dana 300 will drag the ground in the stock position
I have also heard that using just a clocking ring, will not allow for enough engagement of the dana 300 onto the rear out put shaft of the nv3550
I dont want to spend $250 on the kit from Advance Adapters
I would like to redrill the tranny holes and clock it myself
Any comments or knowledge on this swap would be appreciated
guffey24 is offline   Reply With Quote
Old 01-28-2006, 04:15 PM   #2 (permalink)
Vermit's Avatar
Member # 21202
I did that same swap 2 or 3 years ago. I just redrilled the transmission.
Vermit is offline   Reply With Quote
Old 01-28-2006, 07:37 PM   #3 (permalink)
Moderator
apeters89's Avatar
Member # 7647
just get the gotoguy clocking ring, it's MUCH thinner, and you get plenty of engagement that way. I'm running his on my flipped 300 and it works fine.
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 01-29-2006, 01:38 PM   #4 (permalink)
Member # 26465
When I hooked up my d300 I just redrilled it, works fine.
~matt
46 CJ2A, 5.0, C4, D300
MDDimmick is offline   Reply With Quote
Old 01-29-2006, 06:52 PM   #5 (permalink)
Member # 66280
Guys this may sound crazy but are you redrilling the holes in the tranny or putting new studs in the dana 300
On the back of the nv3550 tranny I only have room for one more set of holes, I dont care about having a flat skid plate but, I dont want the 300 to drag the ground either
If you did the swap with a nv3550, and you only have room for one more set of holes how much will that clock it up?
Old 01-30-2006, 04:53 AM   #6 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
I have the same tranny and used the go2guy ring apeters89 mentioned. Its nice and thin and allows you a couple of clocking positions. If I remember correctly I had to oblong one or two holes on the tranny.
Buy the ticket, take the ride.
frostytj is offline   Reply With Quote
Old 01-30-2006, 05:08 AM   #7 (permalink)
Member # 66280
I am going to look at this gotoguy ring before I decide to start drilling holes in the tranny
Old 02-01-2006, 10:52 AM   #8 (permalink)
Member # 66280
Anybody got pics of the hydraulic clutch setup for this particular setup
