Automter Sensors vs. Stock Sensors - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2006, 09:32 AM   #1 (permalink)
Member # 8830
Autometer supplies new sensors with the oil and coolant temp gauges. In a '99 4.0L application, should I use the stock TJ sensors or should I thread in the new ones that automter provided?
I've been reading up on swaping out TJ gauges for the Autometer's, when I came across this:
http://www.pirate4x4.com/forum/showt...ighlight=gauge
"For the temp sensor, I did not drill and tap a new fitting location in the thermostat housing, the block has a coolant drainage hole that happened to be a perfect 3/8" NPT size so I used that.
Its a bitch to get to, and I had to grind down the square side of an extension to fit the hole in the plug, but it wasnt that bad. Nobody in town had an NPT tap so I was impatient and did it this way. The temp readout is the same as the one taken at the top of the thermostat housing."
MARSHY CREEK ROCK CRAWLING TEAM
RSQJEEP is offline   Reply With Quote
