Member # 6312
i have the RE 6in lift & 1 3/4 spacers & 2in body lift & im rubbing the front fenders when turned & flexed , they dont rub when wheels are straight but when turned they are getting into the rear part of the front fender , what should i do , id like to see pics if someone has done trimming on the front to get them tires to clear ,,, i dont want anymore lift on it ,,thanks <IMG SRC="smilies/usa.gif" border="0">
hey newbie <IMG SRC="smilies/thefinger.gif" border="0">
if its just a little rubbin... i say let it rub... also you might be able to lenghtin the lower arms which will help a little.. as far as cuttin there.... depending on exactly where its hittin you will have to plate because you will have a big ole hole there.... and a big dddaaaaaaamn 10 inches of lift! im running 39.5's with only a little 6 3/4 inches of total lift on a tj.... and i dont rub <IMG SRC="smilies/smile.gif" border="0">
Hot Pursuit Rockcrawling #911 [SIZE="7"][COLOR="Yellow"]2006 BADLANDS MOONBUGGY FOR SALE[/COLOR][/SIZE] [url]http://www.pirate4x4.com/forum/showthread.php?t=566987[/url] |
Member # 743
with RE 6" springs and 1" body I rub my 35's but only when stuffed and turned like you say. Its only a little bit so Its no biggy.
I say with all that lift you got you should have already figured out that lift isn't the only answer. Just cut it and weld away.
1993 YJ, SOA, locked/locked, beadlocked 35's, chromo's, caged,OBA, sold. Once again. no jeep. |
#4 (permalink) | |
Member # 7351
I'm not stooopid, I just a newbie. |
Member # 62
There are these real high tech things they make called bumpstops... They keep the tires from rubbing something all the lift springs and spacers in the world won't do (they just effect static ride height and most still allow the tire to compress just as far
Jeff Neves |
Member # 3893
You can also do the low tech solution and glue hockey pucks to the lower spring pad with silicone.
Hey, BellyUp, what 35's are you running? I have 4" Tera springs, 3/8" spacers and 1" body lift and I'd swear I could fit 35's with no rubbing at all! Right now I have 33" BFG MT's (yuck) and I do know they are really small 33's. We rolled out some SS TSL 33's next to 'em the other day and it was a HUGE difference.
'97 TJ - D60 Ford Front, D60 E350 rear, build is going slowly... '06 Dodge CTD 4x4 QuadCab |
Member # 6312
badassjeepguy ,, holy sheep chit , 6 3/4 in with 39.5 , i would really like to see ya fenders , i thought that would work till i started flexing it , i really didnt want to put more bump stop in it ive used some extra bumpstop & thought that would cure it but its a flexy SOB, actually id like to lower it a bit , i have the front control arms extended ,, all is well till i flex it turned as hard as i can , guess ill sawzall!!!!! i need about 2 more inches & thats the only i see it now ,, i wonder what kind of flare i could rig up to it ? <IMG SRC="smilies/usa.gif" border="0">
#9 (permalink) | |
HeiserOilMotorsports
Scott <IMG SRC="smilies/grinpimp.gif" border="0"><><
Member # 6312
i would defiently love to see some pics ,, close up ones too , front & rear ,, ive been thinking of moveing the tank up to where the rear seat goes to get some wheel base under it too <IMG SRC="smilies/usa.gif" border="0">
#11 (permalink) | ||
#12 (permalink) | |
there wasnt much cuttin in the front... rmoved the entire fender, inner and outter, cut the hood 3 to 4 inches higher on each side, cut part of the rocker (plated to cover the whole into the vehicle <IMG SRC="smilies/biggrin.gif" border="0"> ) then tube was bent into fenders tied into frame, rocker, and across the engine. rear was cut as high as poss, rear inners pulled up and re welded, fenders made of tube, tied into cage, frame, then blends into rear bumper... ill look for some pics..
#13 (permalink) |
Member # 5510
just do this to the front of your TJ <IMG SRC="smilies/biggrin.gif" border="0">
Lewis'Cutter'Jones Moab, Utah '99 Disco II TReK and some other junk... www.anasaziexpeditions.com www.moabslickrockhouse.com |
#14 (permalink) | |
Member # 743
Check out my home page for pics of mine and BAJG's just click the little house on this post. [ 10-11-2001: Message edited by: BellyUp ]
#15 (permalink) |
check out, another sawzall session,,, in general chit chat, i pulled it btt so it should be on page one....
cutter.... doesnt look like you cut much.... <IMG SRC="smilies/biggrin.gif" border="0"> go 3 to 4 more inches up the hood.... <IMG SRC="smilies/biggrin.gif" border="0"> then youll be there... <IMG SRC="smilies/biggrin.gif" border="0">
#16 (permalink) | |
Member # 5510
#17 (permalink) |
Member # 7503
I am running the same but with a 1 inch body and 37's and with some cutting I only rub under full gettin it awn compression. Works out fine.
[url="http://www.offroadforums.com"]Offroad Forums[/url] |
