My tj cage build thread - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-04-2006, 08:44 PM   #1 (permalink)
Member # 47179
Send a message via AIM to TotalImmortal
Figured some of you guys here might be intrested
progress after day one
Brice
TotalImmortal is offline   Reply With Quote
Old 02-04-2006, 09:16 PM   #2 (permalink)
Life on the Darkside
Brink_'s Avatar
Member # 63901
Looking good. How was it going through the dash? Big deal? Lots of shit in the way? Or just a quick holesaw and slide it down with the top off?
Brink_ is offline   Reply With Quote
Old 02-04-2006, 09:24 PM   #3 (permalink)
Member # 47179
easiest vehicle to go thru the dash i have dealt with yet. unbolt the dash, pull it out, do your cage work, then when its time to bolt the dash back up find where its going to interfere and use a 1.750 barrel sander to notch the dash. it will contact the AC vent but its flexible enough that it deforms around the tube
Brice
Old 02-04-2006, 09:41 PM   #4 (permalink)
Brink_'s Avatar
Member # 63901
Any chance of a few more pics of it? Specifically the dash work.
Old 02-04-2006, 09:48 PM   #5 (permalink)
Member # 47179
i havent notched the dash on my jeep yet. i'll post pics after i notch it. (probably tomorrow)
Brice
Old 02-04-2006, 10:33 PM   #6 (permalink)
desertsport's Avatar
Member # 39627
looks very clean, But dont you think there should be a little more room between the hole in the tub and the tub going through it to allow for flex. more pics and details would be great.
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56
desertsport is offline   Reply With Quote
Old 02-04-2006, 10:38 PM   #7 (permalink)
Member # 47179
its going to be plated to the tub=no flex.
plates like the ones pictured below will be made
Brice
Old 02-04-2006, 10:55 PM   #8 (permalink)
Big Meanie
Haole's Avatar
Member # 5859
Hell, it can be done without pulling the dash. There's a staright shot down the passenger side and a couple of relays that need to be moved on the driver's side.
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
Ventura County Axle Snappers - Nevada County Chapter
Haole is offline   Reply With Quote
Old 02-04-2006, 11:06 PM   #9 (permalink)
Brink_'s Avatar
Member # 63901
Just holesaw through from above then?
Old 02-05-2006, 06:09 AM   #10 (permalink)
Bending light
BlueAngel's Avatar
Member # 24300
That front windshield bar seems to be very close to the hardtop latches, can you still open these latches?
Project - Destroyer
BlueAngel is offline   Reply With Quote
Old 02-05-2006, 07:29 AM   #11 (permalink)
Member # 37684
[QUOTE=TotalImmortal]its going to be plated to the tub=no flex.
the cage in my cj is tied into the frame in 6 places and it moves inside the tub when the jeeps flexed out. the frame is still going to flex , IMO the plate will eventually rip the tub. your cage looks good and tight fitting but I would leave some room for it to move a little.
madmonk is offline   Reply With Quote
Old 02-05-2006, 07:53 AM   #12 (permalink)
Member # 47179
frame/tub flex= bad. when you eliminate this(through a cage) your suspension handles much better.
rip the tub? lol it wont. there is a lot less flexing around on a jeep tub than a ranger and we havent had any problems with with plate ripping off this truck we built
Brice
Old 02-05-2006, 07:54 AM   #13 (permalink)
Member # 47179
cmon blueangel...have faith of course we can still open the latches......barely
Brice
Old 02-05-2006, 10:23 AM   #14 (permalink)
beartj's Avatar
Member # 30026
Send a message via AIM to beartj
Yup, super simple. Pull the vents and speakers and you'll see. All I had to relocate was the diagnostic port on the d/s and cut/bend a thin sheetmetal flap on the p/s. You can get flex ducting at any NAPA to reroute the venting but I haven't yet and probably won't.
Here's some pics that show where we put mine through* but it's pretty easy to figure it out once you get the vents pulled.
*I'm only posting these pics to help. It's not complete and I know it needs gusseting, etc. all that will be done when we finish the rear. By posting these pics, I am NOT asking for opinions on how well built it is/isn't.
PORCer Fuggy
The Coyote
beartj is offline   Reply With Quote
Old 02-07-2006, 07:07 PM   #15 (permalink)
Member # 47179
udates for today. only worked on it for 4 hours (damn college taking away me wrenching time!! )
-notch dash
-a pillar frame tie in
-weld random crap
Brice
Old 02-10-2006, 09:38 AM   #16 (permalink)
Member # 47179
heres progress from yesterday
Brice
Old 02-10-2006, 09:46 AM   #17 (permalink)
Cue-Ball's Avatar
Member # 17311
I am curious about this pic. Are you making the front bars and A pillar Separate from the rear and welding them together??
Nex Pro Evinco "Death Before Defeat"
Cue-Ball is offline   Reply With Quote
Old 02-10-2006, 09:48 AM   #18 (permalink)
Member # 47179
aka a splice....yes. tube is sleeved with 1.5 and rosetted.
Brice
Old 02-10-2006, 09:54 AM   #19 (permalink)
Cue-Ball's Avatar
Member # 17311
Ahhh, ok, any reason you didn't bend it out of one piece?
Old 02-10-2006, 09:57 AM   #20 (permalink)
Member # 47179
hmm...didnt feel like spending the time to figure out 4 bends for one tube and potentially having to scrap metal if i screwed up . (im cheap and ona budget) its not weak if done correctly
Brice
Old 02-10-2006, 10:04 AM   #21 (permalink)
Cue-Ball's Avatar
Member # 17311
Point taken. I am just anal retentive about that shit. But then again, it's not my jeep. Carry on.
Old 02-10-2006, 06:08 PM   #22 (permalink)
Member # 47179
almost done
Brice
