waggy axle shaft question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-14-2006, 05:19 PM   #1 (permalink)
Member # 16180
Send a message via AIM to redjeepguy
looking around the web this evening i found this site
http://www.teamgrandwagoneer.com/par...ain/index.html
3 items up from the bottom they show front axle u-joints, and they have circle clips. everything i have read says that you have to upgrade to cromo shafts to run full circle clips, so am i missing something or is this website simply wrong? can you run full circle clip u-joints with the stock waggy shafts?
Mark
92 xj-d44's-36" tsl's-chopped rear-fully caged in and out
redjeepguy is offline   Reply With Quote
Old 02-14-2006, 05:43 PM   #2 (permalink)
Cue-Ball's Avatar
Member # 17311
Mark
I thought you could??
Nex Pro Evinco "Death Before Defeat"
Cue-Ball is offline   Reply With Quote
Old 02-14-2006, 05:48 PM   #3 (permalink)
Member # 2114
I believe those clips are the stock ones for most dana front axles....they are a "C" clip only part circle. If someone is refering to full circle clips I believe they are the ones on the outer part of the u-joint. But Maybe someone has the right or better answer
A good friend will come and bail you out of jail.....
but, a true friend will be sitting next to you saying,
"Damn...that was fun!"
JeepManEd is offline   Reply With Quote
Old 02-14-2006, 05:51 PM   #4 (permalink)
Cue-Ball's Avatar
Member # 17311
Ah yes now it's all comming back to me. This sounds Right
Old 02-14-2006, 06:22 PM   #5 (permalink)
Member # 5399
Your intial thought is correct that you cant fun fill circle clips on waggy shafts w/o either grinding or going alloy shafts.
Mel85CJ is offline   Reply With Quote
Old 02-14-2006, 10:30 PM   #6 (permalink)
Member # 19579
Not sure about the full circle clips....
Are you running stock waggy shafts?? Why not run a 760x ujoint??
Izzy II: Lifted, locked, and ready to rock!!
Janster is offline   Reply With Quote
Old 02-15-2006, 08:12 AM   #7 (permalink)
Member # 62
This is a full circle clip like you are refering to:
The link you posted is just some no name replacement U-joint with the stock style retainers.
Jeff Neves
NE-RokToy is offline   Reply With Quote
Old 02-15-2006, 03:34 PM   #8 (permalink)
Member # 16180
yeah, i knew they werent full circle clips, but i have never seen the half circle clips offered with stock replacement u-joints. just threw me off a little.
janster, i have stock waggy shafts, and im still running 297 joints.
the local 4x4 shop offers 760 joints with full circle clips, and im kinda wondering if its worth it just to get the shafts machined to use the full circle clips. most d44's ive seen break are because the caps backed out (and yes mine are tack welded but ive seen the welds break and spit the caps).
