Member # 48233
Got a Welder
Okay so i got myself a free 220volt arc welder for free. I know its noo MIG or TIG, but I'm new at the fabbing thing. Any tips??? I figured I'd ask here cuz this forum is for the fabbers and not bolt types. I'm gunna try to start with shock mounts and pot welds.
Member # 37244
Get some scrap metal and 10 lbs. of 5/32 7018 and practice, practice, practice. Play with your machine on different settings to find what works best and note them.
#3 (permalink) | |
Member # 48233
Member # 48233
Well from what I gather from reading, is that laying a bead down isn't super hard, its just kindof a back and forth motion of the hand kinda like I have palsy, just under more control
Member # 40433
the strongest welds really come from 2 passes, if your doing something thats going to see alot of stress, i would say lay down a pass of 6011 (high penetration but low strength, and then a pass on top of that of 7018 (low penetration but high strength) 7018 is prolly the hardest rod to weld with, once u master that, everything eles goes smooth. id say pick up a big pack of both, and just practice, try different settings on the welder, different angles of holding the rod, anything till you find what works for you.
99 Silverado ext cab SFA, NP200, HPD60/14bff 5.13s on 44" TSLs 07 3500 ram megacab cummins - tow rig |
Doc -
Wrong forum; you want Pirate4x4's Shop and Tool Talk forum. Mad, mad fabbing and welding technical depth. Those guys are the shiite - Good luck
wrapped in pleather |
