I am Fixing to weld some Wagoneer caliper bracktes to my D 44 rear and was wondering if anyone has used caddy calpiers in them? if so what years. I know by using the search engine there are two types, 1 big and 1 small , So which one do I use?
Also, will the 1.120 scout rotors fit them? or do I need to use my 7/8's origanials from my old dana 30?
I still havent gotten a answer on the porpertioning valve, so i am lost on if I should even use it or not.
Well, if wagonner brackets are the same as 1/2 ton chevy brackets which I think they are - then you want the big caddy calipers.
Don't know about the rotors, personally I use the 1.125 jeep rotors, with chevy backign plates and calipers.
What was the question on the prop valve? If you have 4 wheel disks, it's a must - even with rear drums it's nice to have so you can get the brakes set just right.
There's some disc conversion stuff on my site, not sure if it applys to what you are doing. www.oldjeep.com
The Caddy calipers you want are '77-79 Eldorado calipers. Specifically Eldorado as they were the only model to use them. I'm looking for a set to convert my 14-bolt to discs.
My MC is a wilwood, the prop valve is stainless brakes. Doesn't much matter which one you use, they are all basically the same. Yes it is adjustable, would be worthless if it wasn't.
If you are not confident about doing major mods to your brakes, don't. It's a good way to get yourself killed if you don't know what you are doing.
I bought a Wilwood Proportioning valve for my Scout when I swapped in a Camaro MC. It is only hooked up to the rear lines. With that said, I quickly found out that I didn't need while I had drums in the rear. I don't know if I'll need it for the rear disks now(still haven't drove it) It is currently backed all the way off. Try it without and then put on in if you need to. Just test it out in a safe place.
An adjustable prop valve only goes in the rear line, it's used to reduce the braking power to the rear brakes so that you can get all 4 brakes set to lock at approximately the same time.
I chucked my propo valve when going to 4wheel discs.
don't need it, don't miss it.
the difference in caliper bore size acomplishes the same function, espically on an SWB
