Someone told me that RE makes a SOA Spring, but didn't have any other info. Can anybody out there tell me more about there besides that there $125 each. Like ride, performance, flex,........
i personally don't know a thing about them but i run rear cj 7 leaf hd spring from jc whitney at all 4 corners with good luck. i have a cj but it has been talked about as a good swap for yj owners too. plus they are only $69 per spring new. i say run these and spend the $$$ you have left over on something else. just my op.
You are the second post in a row that I am reminding to use the SEARCH button and look this up!!:flipoff2: There was just a thread here on Pirate about this same thing. We even had a comparo of springs with pics and diagrams. Use the SEARCH and check it out!! :beer:
BTW ... :flipoff2: WELCOME to the Dark Side NEWBIE!! :flipoff2: :vader: :flipoff2:
I did a search but after the first 150 threads that didn't answer my question I desided to post a new thread. So maybe a little help would be more appreciated then, alot of posts that say do a search.
Yes they do. I have them on my YJ. No complaints from me. I have 5 packs all around though. They are reverse eye. I dropped $600 for the springs only so that is the only thing I dislike about them. Other than that they flex great and the ride is smooth as can be for a Jeep. I will most likely go with them again when it is time to replace them. :flipoff2: :flipoff2: :flipoff2: :rasta:
The 6 leafs were a bit too stiff for me. I had nothing in the back of my YJ at the time I got the springs. So there was no weight on the springs. I have a full size spare (35" tire) in back now and it and it is still just right. I might go with the 6 pack if I had a tire carrier and some other gear in back.
They were not that bad but I wanted it to be a little more softer. It flexed better with a softer spring since I had no weight in the rear. The fuel cell will add some more weight when full so the 6 pack may be good for you. It would help a little with axle wrap but they will break in eventually and start to wrap. You would want to go with some kind of wrap bar down the road. At least I would anyway. I am planning on going with a swing out carrier so I will get the 6 pack then. I hope that helps :rasta:
they flex really well and i do run the overload leaf in the front but not the rear. i run a antiwrap bar in the rear so the overload leaf was not needed and i started out with out it in the front but after some wrap in the front i put it back in. like i said they do flex really well!
I just finished with a cj7 and the 6leaf hds and they work out great. My buddy likes them. I would recommend the anti-wrap bar as soon as the springs are on and settlrd for a month or so. The anti-wrap bar is necessary before any hard wheelin in my opinion. We wrapped the first pair in the rear on my tree ramp just throttling it.
yes an anti wrap bar is needed for just about any soa. you will need one for these springs. i would bet $$$ you would need them with the re springs too. any spring that is going to give any kind of flex will require one.
First of all, protocol dictates a :flipoff2: and welcome!!
Secondly, the eye is reversed to help eliminate spring wrap in a SOA application. SUA springs are desinged to be used that way and wrap easily because of it. The eye being reversed helps to "disperse the load" when under power and the axle is trying to twist.
So the reverse eye is to help eliminate axle wrap except, by RE own words, it doesn't. You will still need a traction device to control wrap. Seems to me they charge a hole lot more $$ just because they are reverse eyed.
NOw, if the reverse eye helps the springs last longer , that would be worth it. Aything to keep me wheelin' and out of the garage on weekends
