HP D44, uses the same master install kit??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2006, 10:57 PM   #1 (permalink)
Member # 49320
Not exactly hardcore tech but...
I'm building my first axle, a high pinion dana 44.
Does a Ford high pinion dana 44 use the same R&P master install kit as the low pinion dana 44?
I can get a d44 master install kit from someone that bought it and now doesn't need it, for a very good price, but I want to make sure it will work with my hp d44. It is a Sierra Gear & Axle Installation Kit, part number IKD44.
The description on thier web site is:
Dana 44 30-Spline Master Installation Kit.
Master Kit Includes:
Timken Bearings, Pinion Seal, Crush Sleeve, Pinion Nut, Pinion Shims, Carrier Super Shims, Slinger, Baffle, Ring Gear Bolts, Loctite, Marking Compound, Brush, Silicone & Instructions
I could not locate a high pinion specific kit, so it would appear that there is no difference. I'd like to make sure before I buy this kit.
Sierra Drifter is offline   Reply With Quote
Old 04-26-2006, 08:11 AM   #2 (permalink)
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
yes
Only in a Jeep
Murfman is offline   Reply With Quote
