i have an 82 cj7 and when i turn the jeep on both the fuel and gas guages go straight to full / hot respectively. i was wondering if anybody has had this happen to them or something similar. to me it sounds like the guage is grounding out, but where should i start to look.
Dont feel alone mine do the same thing . I hadnt figured it out yet . Ive checked the wires ever thing seems ok but they still dont work .Soif you figure it out let me know
Dirty blue cj:flipoff2: :flipoff2: :beer: :beer: :beer:
Well obviously as you said, you've got one of the sender wires shorting out to ground. Easiest way is to get a multimeter and pull the sender wires off the back of the gauges and one at the time measure the senderwire for continuity to ground. Once you know which one of the two wires is causing the trouble, trace it back to the sender and check for damage. If no damage can be found, it could be the sender itself. On the temp sender you can disconnect both sides and check for continuity to eliminate the wire itself. On the fuel gauge it is a bit more difficult as you can't reach the wire. If the fault appears to be in the fuel gauge wire chances are that the fuel sender has fallen to bits (the resistor wire had broken)which is what happened to me. In that case you will have to drop the tank to replace the sender.
i have a new sender assembly but haven't had the time to drop the tank due to school. i am also installing a new rear bumper/swing-away in hte next few weeks and the gas tank has to get dropped then so i will do it then
a piece of 1x1x2 stick with cut outs in it, 1/4 1/2 full
