Member # 34440
4.2l to 4.0l tach issue
I'm looking at buying a 90 YJ that had an 99XJ 4.0l swapped in and have a few questions for yall.
The guy said they never wired in the tach ... something about how it could mess up the computer? Is there something I do not know about wiring in a tach? Should I have any problems if I try to install an aftermarket tach? Is there a way to run the 90 tach?
noeither.com |
Member # 62615
There should be a signal wire coming from the MPI harness. When I swapped in my MPI kit, it was grey with a blue tracer. That is the signal wire. I had to then run the ground to the negative side of the coil to get a correct read out. When and if you have to do this, do it with the engine running since when you splice into the negative side of the coil, it can short out the computer and then it wont be able to run. I am running an Autometer Phantom Tach and it is a lot better than the factory stuff.
Matt
Unstacking Hardass |
Member # 24805
And if you use the factory tach, you DO NOT use the MPI signal wire.
I'd have to look through my MPI notes, but you connect the factory tach to the coil IIRC.
'89 YJ |
Member # 5344
On the 4.0 just splice into the green wire on the coil to the hot lead to tach and then ground.
If you don't learn from History, then you are doomed to repeat it |
#5 (permalink) | |
Member # 34440
Thanks for all the help guys.
noeither.com |
I think he means do it on a known running/functional vehicle, not during an engine swap since it could cause a no start problem....
the stock computer out works for 4 cylinder tach's. On mine I just tapped the secondary coil wire like everyone else on this thread so far. Last edited by CJ5-Man; 05-04-2006 at 05:56 PM. |
