Will a '96 AW4 fit a '97 4.0L? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2006, 12:27 PM   #1 (permalink)
Member # 51407
I have a 1997 4.0L out of a XJ in my CJ mated to the stock TF999. I want to replace the TF999 with a AW4 to get an overdrive, etc. There is a local guy selling a '96 AW4 out of a XJ for $450 with TCU. Is this compatable with my 97 4.0L?
Thanks,
Jason
1986 CJ-7 with stuff
Jay5.9L is offline   Reply With Quote
Old 05-15-2006, 03:24 PM   #2 (permalink)
Member # 67781
http://www.stu-offroad.com/engine/aw-4/aw-4-1.htm Good link for AW4 swap info
nope it wont work 97 they changed the connectors on the Aw4. I'm a in the prosses of swaping one in to my YJ and got a AW4 from a 93 XJ and got a 99 Xj wire harness connectors are diffent. but if you have a factory survice manuel and cut the wire and wire it in that way then it could work. Another thing make sure you have the connector for the TCU 87-96 was a 32 pin and 97-01 is a 26 pin.
ksejeeper is offline   Reply With Quote
Old 05-15-2006, 03:36 PM   #3 (permalink)
Member # 51407
Oh good info!!!!!!!!!! Thanks a lot!!
Old 05-15-2006, 04:10 PM   #4 (permalink)
Randall Edge's Avatar
Member # 12992
Send a message via AIM to Randall Edge
What kind of harness and PCM are you running now?
'48 Willys Truck.....sorta......
Randall Edge is offline   Reply With Quote
Old 05-15-2006, 04:16 PM   #5 (permalink)
Member # 6562
I just got done swapping in a '91 AW4 into my '93 YJ which came factory with a 999.
Not sure if it will help much with your application, but it might.
You can read up on my swap here: http://www.jeepin.net/forum/showthre...t=27473&page=8
Tranny wiring stuff starts about halfway down that page.
Also, I documented my wiring in a complete list. You can see that here:
http://www.phatserver.net/temp/YJ_WiringList.xls
3/4 Ton YJ
PhatXJ is offline   Reply With Quote
Old 05-15-2006, 04:57 PM   #6 (permalink)
Member # 51407
I'n not 100% sure but I am guessing the '97. The previous owner did the swap and I think everything came from the doner cherokee. I wish he swapped in the trans at the same time.
Old 05-15-2006, 06:01 PM   #7 (permalink)
Member # 11998
Send a message via AIM to BrettM
It can be made to work, it may only need a few wires spliced over, but some people have had to change the speed sensor in the tranny. or the electronically easiest way it to change it to manual only control (link in sig)
awshifting.com
awshifting@gmail.com
BrettM is offline   Reply With Quote
Old 05-16-2006, 03:43 AM   #8 (permalink)
Member # 12992
Do you have a check engine light and does it work?
I do know that '97 AW-4's and '97 TCU's are not interchangable with any other years, so if you have a '97 tranny you need a '97 TCU. I don't know if another year will work with your engine if you change both the tranny and TCU at the same time. If you have the correct connectors on the harness already you could just hook it up and see if it works and if not you could cut out the connectors needed and splice it in like those of us who have installed an AW-4 into a TJ.
Old 05-16-2006, 06:27 AM   #9 (permalink)
Member # 51407
No check engine light. It on my to do list. How much longer is the AW4 over the TF999? Are you guys liking the swap and is the oer drive worth it?
Old 05-16-2006, 07:48 AM   #10 (permalink)
MRJ
MRJ's Avatar
Member # 24868
Jay,
Come over and drive mine. We had all the wiring in place for the 97 swap. I just didn't think i had it right so we went with the 99 AW4 and TCU. After doing that swap I am certain I had the 97 wiring correct.
Mike Judd
President
[URL="http://www.summitmachine.com"]Summit Machine, Inc.[/URL](801) 576-8424
MRJ is offline   Reply With Quote
