Chucks CJ 8 build up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-20-2006, 11:19 AM   #1 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
Chuck brought me this CJ 8 and told me he wanted a trail rig that could run hard core trail and still be streetable. We gutted the whole rig and started over. I found an 04 chevy 6.0L V8 with only 12k on it, an NV 4500, and put a 4 sd Atlas on order. For axles we got a 1990 ford HP 60 for the front and a dodge full float 60 for the rear. Axle are stuffed with 5.13 gears, ARB's, and all 35 spline. XJ rear leaf springs front and rear and 40" MTR's. This rig is going to be able to get it and still drive home.
TRENT FABRICATION
www.trentfabrication.com
775-358-5337
Tfab is offline   Reply With Quote
Old 05-20-2006, 11:23 AM   #2 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
Poison Spider fenders, rockers, and corners beef up the body.
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 11:29 AM   #3 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
Trever from WFO sent me these sweet double ended high steer arms. The tie rod and ram are behind the axle. Thanks Trevor
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 11:34 AM   #4 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
This is the first 6.0 through the shop. We striped about a cubic yard of wiring and sensor off the thing. Hope Towner can figure out where it all goes.
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 11:46 AM   #5 (permalink)
Member # 47905
I wish mine was that far along. I've got the most of the parts just waiting for the shop to get done to put them together. gm 6.0, Nv4500 32 sp. output, D300 32 sp. input, 32 sp. outputs, gm d60 in front and a c14 out back, both w/ arb's, rolling on 39.5 iroks wraped around recentered hummer rims. the rest is just details. I'm debating wether to straighten the frame and weld on plates or go with a TDK frame since I tweaked mine in the rollover I had. The tornado we had around here messed up one of side panels a little more than it already was but it needed a little body work anyway. I'll be watchin' this thread closly.
Bowtie Binder is offline   Reply With Quote
Old 05-20-2006, 12:21 PM   #6 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
Rear wheel opening need to be opened up a little and then rear tube flares will be built.
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 12:59 PM   #7 (permalink)
Member # 50676
Send a message via AIM to crapxj
89 xj-not stock. dd/trail rig/winter time rally truck lol
-OllllO-
crapxj is offline   Reply With Quote
Old 05-20-2006, 01:13 PM   #8 (permalink)
Member # 17918
Send a message via AIM to imgonnasnap
sick 8!
"Your life is one giant redneck moment"
imgonnasnap is offline   Reply With Quote
Old 05-20-2006, 01:31 PM   #9 (permalink)
Member # 57118
Nice so far....What ECU ya gonna use for the motor then if you're taking off the stock stuff?
mysunnshine is offline   Reply With Quote
Old 05-20-2006, 01:34 PM   #10 (permalink)
syko's Avatar
Member # 746
Send a message via MSN to syko
Did you cut and rotate the knuckles to set the the right caster? Hell, show some pics of the arms. I need to buy a set.. My scrambler looked like that at on time....:>D
8.8876 @ 76.80mph in an 1/8 drag
Look for us on Facebook
[U][B][COLOR="Red"]Sponsors[/COLOR][/B][/U]
Fourward Motentum
Driveline Specialists
BFGoodrich
Art Carr Performance Products
Advanced Adapters
PSC Motorsports
Allied Wheel
East Coast Gear Supply
Bulldog Winch
Reid Racing Inc
syko is offline   Reply With Quote
Old 05-20-2006, 02:23 PM   #11 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
pic of WFO arms. www.wfoconcepts.com
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 02:27 PM   #12 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
We always cut and turn axles to get ideal driveline angles
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 04:01 PM   #13 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
thats a badass build up....keep the pictures coming.....
UCTJ is offline   Reply With Quote
Old 05-20-2006, 05:32 PM   #14 (permalink)
Member # 16589
Ecu
If it wasn't for OBDII needs it would be a Haltech in a minute but we need to get everything emission legal. We need to find out if a single cat with two O2 sensors will work or if we have to do duals and four sensors. The 6.0 was an Auto and we might have to find an ECM for a Std. The fuel tank/cell is another consideration. We'll be using Howell to get the the harness correct. Are there any referee's on the board to get us straight the first time around
Towner is offline   Reply With Quote
Old 05-20-2006, 06:36 PM   #15 (permalink)
Member # 343
Any plans to "bob" it? Cool rig, I like it....I am kind of partial to scramblers.
cj8scrambld is offline   Reply With Quote
Old 05-20-2006, 07:04 PM   #16 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
If it were my rig it would already be bobbed with a sleek cage and 4 PRP buckets with O shiz-nit handles for all passenger seats.
Chuck wants a spare tire rack on the back with a cooler mount behind it. Also a cage inside the hard top and an exo cage outside the hard top (so the top can be removed) with land cruiser back seats that mount to the exo cage and fold out sideways. We want to get the boards opinion and have Chuck get the best rig possible. Bring it awn.
TRENT FABRICATION
775-358-5337
Old 05-20-2006, 07:26 PM   #17 (permalink)
syko's Avatar
Member # 746
This is what I did for the inside cage:
I wanted a cage in the back but couldn't come up with anything that allowed you to remove the top and not look like ass. I ended up just using the stock bar. (which I still have sitting in the shop) Look forward to see what you guys come up with.........If I did it again I would run the hoops from A pillar to B pillar. I love having a flat side. The way I had it, if you laided into a tree you would hang.
Man, I kinda wish I still had a body
Fourward Motentum
BFGoodrich
Advanced Adapters
PSC Motorsports
Allied Wheel
Bulldog Winch
Reid Racing Inc
Old 05-20-2006, 07:44 PM   #18 (permalink)
Gunmetalcruz's Avatar
Member # 6569
this is what we are used to building. Come on challenge us, bring it boys
Team FOH# 321
Thanks to the people making it happen
Weathertight,Polyperformance,CTM Racing Products,Levrett Transmission,BFGoodrich Tires,Kickass Offroad,Reid Racing,West Coast Differentials,Wide Open Design
Gunmetalcruz is offline   Reply With Quote
Old 05-20-2006, 07:52 PM   #19 (permalink)
syko's Avatar
Member # 746
How can you be challenged? Doesn't he want a basic trail rig?
Fourward Motentum
BFGoodrich
Advanced Adapters
PSC Motorsports
Allied Wheel
Bulldog Winch
Reid Racing Inc
Old 05-20-2006, 09:19 PM   #20 (permalink)
Member # 6569
We are hoping for a barely street legal gettin it rig,
Team FOH# 321
Old 05-21-2006, 06:06 PM   #21 (permalink)
OkLaHoMaYJ's Avatar
Member # 17969
Send a message via AIM to OkLaHoMaYJ
Let us know how the rear XJ springs work in the front. Interesting setup.
2012 F150 FX4 EcoBoost - Wanting a built LJ/JKUR
OkLaHoMaYJ is offline   Reply With Quote
Old 05-21-2006, 09:56 PM   #22 (permalink)
Member # 65012
NICE. How much money will you have in this when all is said and done?
i should have bought a CJ!
To err is human. To arrrr is pirate.
Greg_Volkman is offline   Reply With Quote
Old 05-22-2006, 08:47 AM   #23 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
That all depends on how much detail work gets done. At this point it's to soon to tell.
TRENT FABRICATION
775-358-5337
Old 05-22-2006, 08:50 AM   #24 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
Thanks for posting pics of the cage pulled from the rig. It gave me some ideas. I am now thinking of two cages, one for the summer and one for the winter.
TRENT FABRICATION
775-358-5337
Old 05-22-2006, 11:33 AM   #25 (permalink)
syko's Avatar
Member # 746
Anytime, Now get the man's cage built......
Fourward Motentum
BFGoodrich
Advanced Adapters
PSC Motorsports
Allied Wheel
Bulldog Winch
Reid Racing Inc
