dodge tf727 and dana300 help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-05-2006, 08:58 PM   #1 (permalink)
Member # 54975
Send a message via AIM to Plato2k5
I have a dodge tf727 transmission and have a dana300 with the DOE flip kit. Can i just drill new holes into the transmission housing or drill holes into the dana300 casting and tap them instead of buying a clocking ring??
Plato2k5 is offline   Reply With Quote
Old 06-05-2006, 09:08 PM   #2 (permalink)
Member # 64123
clocking ring is the better way to go
starting all over
jpmikey is offline   Reply With Quote
Old 06-05-2006, 09:12 PM   #3 (permalink)
Member # 54975
i understand but i am trying to do everything that i can on this build to save money. I was just asking if this is at all possible.
two of the 5 (i think studs??) fit in holes already on the trans. If i just fill the other 3 stud holes with weld and than re-drill them to line up with the trans..... will this work. Or can i not drill into the case as it will mess it up with running into the gearing and crap????
Old 06-05-2006, 09:17 PM   #4 (permalink)
Member # 64123
drilling into the t case there is not much mat to hold on to the trans side may be thicker
are you using a jeep motor?
starting all over
Old 06-05-2006, 09:23 PM   #5 (permalink)
Member # 54975
no i'm using a mopar 360. Comming off the transmission is a long tunnle with a long shaft into it. Than the transfer case bolts to that... There dosn't seem to be alot of material on that to drill and plus its aluminum i would not want to weaken that with more holes.......
Old 06-05-2006, 09:36 PM   #6 (permalink)
Member # 5021
Buy a go2guy flipped clocking ring and dont worry about it.
Or, you could save $100 now and get on the trail and rip your t-case off your tranny and get to fix the tranny, t-case, drivelines and yokes.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
