spacer amc 327 automatic tran - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2006, 06:06 PM   #1 (permalink)
Member # 74688
Is there a spacer between the crankshaft and flywheel to make an auto trans fit i took out a standered tran and the auto flywheel wont fit it hits the engin block the only thing I can think is there was a spacer on the engine I sent to the wreck yard dose anyone know anything about the change and where I might get that spacer
Don Flahaut is offline   Reply With Quote
Old 06-29-2006, 05:33 PM   #2 (permalink)
Member # 74688
spacer/adaptor
Ok I know there is a spacer/adaptor to make my automatic flywheeel bolt up to my 327 amc motor question is can I find one in this world stupid me didnt see it when I sent that 66 wagoner to the junk yard now I need it back shit happens can anyone find me one for sell of free please help
Old 06-29-2006, 07:23 PM   #3 (permalink)
Member # 20092
Call Salvage Jeep Parts at 912-587-5918.
Ask for Mr Newsome.
They are located in Statesboro Georgia and have the largest jeep junkyard in the southeast. If they don't have it, then they may be able to point you in the right direction.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
Old 06-29-2006, 08:19 PM   #4 (permalink)
Stuka's Avatar
Member # 74795
The '66 had an AS-8F I am assuming? If so, the engine it came from would have had an engine plate on the back, its fairly thick and looks like part of the engine if its dirty. The crank flange would have been different as well. There is also an allignment proceedure for getting the crank and torque converter housing alligned to each other.
Stuka is offline   Reply With Quote
