Member # 51913
STaK Monster 3 speed TC
Any opinions on the STaK Monster 3 speed TC, 5.44?
Reliability, installation, ease of use etc... I have a YJ 4.0 and would be hooking it up to an AX-15. Thanks, as always. |
Member # 59287
I've had mine on for about 6 months now, mated to an 32RE(?) auto and has been flawless. You should expect to tinker with the linkage adjustment a bunch to get it the way you want. Much easier to have two people to install, but I did it myself with a lift and and alot of elbow grease. The more I use it, the easier it is becoming to shift; the gears do bind and have required me to go forward and reverse to get out of low range. But this is becoming less of a problem the more it's used. Also, keep in mind that you're going to need new drive shafts.
Member # 21815
I put mine in a CJ, generally the same impression as HVAC...love the gear choices, it works smooth, the shifting was tight at first but is fine now. Check my sig for the build page.
WWDD? N6YBH - "If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford Use Goodsearch and support the Rubicon Trail Foundation. |
