Member # 3310
3000 RPM Sustained on a 4.0L?
Will a stock 4.0L handle 3K RPM sustained for hours on the freeway?
I'm regearing from 4.56 to 5.42s to handle the 40's and with no OD at 65 MPH, I should be at just under 3000 rpm. I could do 5.13s, but I'd like to go as low as possible. |
our jeep speeds sit on the rev limiter for sustained periods of time, and are almost always over 3k during a race, sometimes up to 9 hours at a time... seem to be holding together great so far... now the motor mount boss's in teh block are another story...
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports |
Member # 22176
I have driven to Moab and back (1,000 miles each way) and the Rubicon (500 miles each way) in my 98 TJ tacking over 3k there and back several times. It still makes fine power and doesn't burn oil.
I can break a steel ball in a rubber room! |
HeiserOilMotorsports
Back when my YJ was a daily driver, my jeep sat at 3k and above for 120 miles round trip, every day at 65 mph, and it still runs damn good with 226k miles on it.
Scott
The Devils Trailboss
Member # 51571
I spin about 2800 RPMs while on the freeway daily...so far no problems since its pretty much within a good RPM range. If I could run 5.13s I would, but I run 4.88s right now and 35s.
Member # 72257
I used to run my 4.2 between 3k and 3200 RPM on the interstate 4 hours at a time sustained, without any problems. If a 4.2 can do it, a 4.0 sure as hell can.
I drive the fastest barbecue on 4 wheels... |
#9 (permalink) | |
Member # 12918
- Chris
Trailed, not trailered. |
#12 (permalink) | |
yeah i used to run 456's 38's 4.0 with the 3 spd auto.
used to run for 3 or 4 hours and never drop below 3-3300rpms never hurt the motor but i did blow 3 tranny's
Its all about the Bling!!!!!! "no voodoo, no black magic" -- BillaVista Quote:
#13 (permalink) | |
honda powered buggy project. build thread comming soon. |
#17 (permalink) |
Member # 14470
3000 rpm @ 70 MPH. Been there, Done that.
sustained 4 days crossing west to east thru the desert. Plus multiple rides from LA to SanDiego 1.5 hrs 1 way 2.5 hrs to JV to wheel. Rode up to Pismo, 4 hrs, same numbers NP435 and 456's with 35s will do that. Be very sure you have a powerful fan for your cooling system. other than that, youll perk around 210-220F which isnt bad for a Jeep. My 4.0 came from an XJ donor 3yrs ago with 65K. now at 102K. I still do 70 on the highway on a regular basis. Run It. CB
[COLOR="Yellow"][B]Crawl rocks instead of smokin 'em.[/B][/COLOR] Rock Rated,4.0,Gears,Lift,Tires,Armor. [COLOR="Silver"]Hardcore, Old-School and Sexy, TSL-SX[/COLOR] [QUOTE=Steve N]Thread poster may be hardcore. Post is not. So this is in wrong section.[/QUOTE] |
#19 (permalink) | |
Member # 50242
Well, THAT's an image i didn't need.... But for the originial question: I also run mine pretty high. I have 4.88's turning 33 inch tires. - Great on the trails; kind of irriataing on the 3.5 hour trip to the mountains. But no problems. And my engine has a quarter Million miles on it.
... Shit happens. Carry a shovel. ... |
#21 (permalink) |
Member # 22646
Like everyone else has said...it will be fine. I run mine at 3000 - 3200 rpm with the 4.0 / ax15 /5.13 gears and 37" Krawlers on beadlocks....no problems. 72k on the motor and the original clutch
" Never underestimate the power of idiots in large groups" |
#23 (permalink) |
Member # 50242
That's interesting.
I'd really like to see that chart. Is it online somewhere? If so, please post a link, or PM it to me. - Thanks
#24 (permalink) |
Member # 44579
Yes 3K is fine.
My 94 XJ has 4.0 HO with the AW4, 5.38's and 35's. Even when I'm not on the freeway I drop it in 3rd to keep the RPM's up.
[b][ ] [u]l l l l l l l[/u] [ ][/b]Save your money for gears and swampers then save money on your lift by cutting out your fenders. |
#25 (permalink) | |
98 TJ, goin crazy with the sawzall [url=http://www.4x4tj.com]www.4x4tj.com[/url] - the Jeep |
