Member # 74368
bump stops
so I got a 1990 jeep yj, axle over, 2.5 lift leaf, 39.5 irocks, and dna 60's. The problem is I have no bump stomps, And am having some issues with the shocks botteming out.. Since this rig is so mod. any stock set up doesnt fit..I have 3 to 4 inchesof up travel and 6 to 7 of down.. any sugestion
??? Project Mud edmonton Canada |
Member # 14470
get shocks with a lifetime warrantee and change them more often.
or get cheap ass shocks, and change more often.
[COLOR="Yellow"][B]Crawl rocks instead of smokin 'em.[/B][/COLOR] Rock Rated,4.0,Gears,Lift,Tires,Armor. [COLOR="Silver"]Hardcore, Old-School and Sexy, TSL-SX[/COLOR] [QUOTE=Steve N]Thread poster may be hardcore. Post is not. So this is in wrong section.[/QUOTE] |
#4 (permalink) | |
Member # 22176
Lame. Rancho has urethane bumpstops in various heights or space the stockers down.
I can break a steel ball in a rubber room! |
Member # 21815
These are Energy Suspension on a custom mount made from .250 wall 1"x 2 1/2" C-channel, similar setup to yours (40"MTR's on SOA YJ). They work quite well. I made them and welded them to the frame.
WWDD? N6YBH - "If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford Use Goodsearch and support the Rubicon Trail Foundation. Last edited by resqme; 08-10-2006 at 11:57 PM. |
Member # 67882
How hard is it to fab up some mounts. just buy some Energy Suspension bump stops. and fab up a mount. You should look in eBay. they sell some nice Rancho bump stops, pretty cheap
120 fabrication Two fj40s on 60s |
Member # 42446
hopefully with that combination and work already done on it you are not still using the stock shock mounts or equivalent. build mounts that will allow you to run the right length shock that in tern will allow you to stuff your tire into your sheetmetal enough to stop upward movement.
#8 (permalink) | |
Member # 74368
The picture helps.. Just wanted to see what others had done, Not wanting to re-invent the wheel so to speek..Thanks for the input guys
#9 (permalink) | |
Member # 21815
I'm pretty sure you guys don't want to use your shocks as bump stops...real good way to break a shock or shock mount (causing who knows what other damage), and I'm thinking the manufacturer isn't going to warranty that. I wouldn't. The title of this thread should be, "Of course I want bumpstops, you dumbass!".
WWDD? N6YBH - "If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford Use Goodsearch and support the Rubicon Trail Foundation. |
#10 (permalink) | ||
Member # 14470
2-Hardcore Tech, right? D60 and he "needs" to ask about bumpstops, I call B-S 3-spellcheck is your friend resqme 4-
#11 (permalink) | |
Member # 22176
He said shocks...Rancho's barely qualify.
#12 (permalink) |
Member # 40958
You wouldn't get anybody to honor a warranty for broken mounts.
Lengthen your shock mounts by the amount you need for them not to bump against anything on compression or on extension. Get some bump stops because when you bottom out something's going to hit hard anyway. If topping out is hard get some limiting straps. |
#13 (permalink) |
Member # 21815
I'll ignore the spellcheck comment...glass houses.
I think someone needs common sense check...because you have been using your shocks for bumpstops for however long (ten minutes or ten years) doesn't make it a good idea. Is it hardcore? No, not really, this thread should probably get moved to noob. On the other hand, blatant misinformation doesn't belong in here at all.
