Rear Axle-Tapered Axle Shaft Hub Removal Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-01-2006, 07:22 PM   #1 (permalink)
Member # 78677
after trying to remove the hub with a puller and beating on it with a mall,it seems a hot wrench must be the only answer for removal...
any tricks would be nice to know...
I just want to re-clutch the powerlok diff...
eMan04 is offline   Reply With Quote
Old 09-01-2006, 10:28 PM   #2 (permalink)
Member # 21815
Is this an AMC20 rear end?
WWDD?
N6YBH
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
Use Goodsearch and support the Rubicon Trail Foundation.
resqme is offline   Reply With Quote
Old 09-01-2006, 11:49 PM   #3 (permalink)
Member # 28566
I'm guessing it is for an AMC 20.
If so:
1) NOT hardcore.
2) You gotta use a real axle puller, it doesn't matter how big a gear puller you put on it, you're not gonna budge it.
3) "Tap" the wings of the butterfly around. (I use a full arm swing w/ a 5lb sledge.)
4) Every now and then, give a nice robust smack to the end of the puller shaft. The shock is what pops the hub loose, not the force of the puller.
5) Keep at it. It takes more perserverence than gorilla tactics.
LilRocky is offline   Reply With Quote
Old 09-02-2006, 04:48 PM   #4 (permalink)
nhgpnut's Avatar
Member # 42521
Send a message via AIM to nhgpnut Send a message via Yahoo to nhgpnut
i've pulled these with ease just using the brake drum like a slide hammer .flip the drum around backwards and put all the lug nuts back on making sure to engage the same amount of threads on each one.use the drum like a slide hammer.i've pulled probably like 5 this way never had much of a problem.
nhgpnut is offline   Reply With Quote
