Member # 56715
Anyone know anything about SpeedGlass?
Hey guys,
The only reason I posted this here is because no one seems to know about this so I thought you guys might. If its in the wrong forum I will post it in the other one. I am thinking about using speedglass(lexan) for my 99' Jeep Wrangler 4.0, its a daily driver and im tired of replacing my window every 6 months. I know that speedglass isnt dot approved and im ok with that. Are any of you running it in your rig right now, or know of someone with it? And if so how well does it work, does it leak, does it scratch and how hard was it to install? Any other information would be greatly appreciated. Thanks in advance, Brannon |
Member # 6052
I know some early bronco guys run it. Only negative thing I’ve heard was that it tends to create a lot of “static cling” like when you pull your cloths out of the dryer. This causes an accumulation of dust. Especially on the inside.
'73 Bronco Growing pile of parts. 4 years is long enough! |
Member # 16052
I bought it from a wholesale plastics business, bought enough to cut out a tj windshield for 90$. Make sure you get the lexan with the MR10 coating, easy to cut and easy to mount. The hardest part was getting the glass out and cleaning up the frame. I just drilled and mounted with stainless nuts and screws, used double sided tape for between the lexan and frame. Mine is trail only, but its been hit hard with rocks and limbs, no scratches or cracks. I bought 1/4 inch, which I've been told was way overkill. Been on about 4 or 5 years, zero problems. This is the same material as speed glass. If you could use a rubber gasket, like on the older jeeps, would be almost impossible to tell the difference between glass or lexan.
POS TJ, is your shit running? Usual Suspects Offroad |
Member # 42791
After breaking 3 winshields in 2 months I put 1 in my scrambler. It's been in there 2 years now and has held up fine to driving on the road. It has a few scratches but no worst then glass and I don't have to worry about breaking it.
#5 (permalink) | |
Addicted to Gear Oil
Member # 56050
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
Member # 39627
I was always curious about how it breaks. Does it break like safty glass, or does it break in to sharp shardes of plastic???
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56 |
Member # 56715
Well guys thanks a ton for the info. I think i am leaning towards that vs regular glass. If anyone else has any information it owuld be greatly appreciated. Hey Cj8 how has it held up to the windshield wipers?
Thanks, Brannon |
#9 (permalink) | |
Lame Sig Line |
#10 (permalink) | |
Member # 42791
#12 (permalink) |
Member # 68171
It’s illegal to use on the street by DOT standards. Because it’s almost imposable to break, rescue workers can’t get through it…
Knuckelhead Last edited by Knuckelhead; 09-26-2006 at 04:36 AM. |
#13 (permalink) |
Member # 56715
Any tricks for getting the old glass out without breaking it? Any any tricks with getting the speedglass in? Should i just use window adhesive so secure the speedglass or use both the gasket and the adhesive. Any info for either question would be great.
Thanks, Brannon |
#14 (permalink) |
Member # 42791
When I put mine in my scrambler I installed it just like the regular windshield with the rubber gasket. I would think that to put it in a tj that it can be glued in just like the stock one. I know that it is not dot approved, but with the inspection sticker on the windshield it looks just like a normal piece of glass.
#16 (permalink) | |
Member # 5639
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. |
