what do u sbc guys run for exhuast? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2006, 10:37 PM   #1 (permalink)
yjw/350's Avatar
Member # 67443
ok well both sides snapped off at the header flange last weekend at paragon so now i need to do the exhaust correctly so it doesnt happen as easily again, who makes a good shorty or block hugger header for a SBC in a YJ?? i had FM 40s on it but they just got beat to shit cuz they are huge, what do u run for mufflers? i was thinkig just straight pipes to just past the t-case but not sure how loud that would be
90 YJ SOLD
2005 Suzuki Kingquad 700 4x4 sold
99 dodge 2500 SLT quadcab longbed 8.0L V-10
FOR SALE or TRADE
[url]http://www.pirate4x4.com/forum/showthread.php?t=608210[/url]
yjw/350 is offline   Reply With Quote
Old 10-03-2006, 12:53 AM   #2 (permalink)
Member # 28566
Search.
You'll find out all about ram's horns and running 2 into 1 via a "Y" pipe.
LilRocky is offline   Reply With Quote
Old 10-03-2006, 12:54 AM   #3 (permalink)
Erik D_lux's Avatar
Member # 1007
I hated all my headers on my SBC. I run stock ram horns now. But I am willing to give up the little hp that it gives me. The ram horns are much smaller and easier to make your own exhaust tight and up higher too.
[B][COLOR="Gray"][SIZE="4"][url]www.DLUXfab.com[/url][/SIZE][/COLOR]
[/B]
Erik D_lux is offline   Reply With Quote
Old 10-03-2006, 07:42 AM   #4 (permalink)
Member # 44231
I'm running a set of Hedmann conversion headers, work fine for me. Short, rear dump, and super easy to fab my own exhaust the rest of the way back, all above frame level. Running 2-1/4" pipes with bullet style mufflers (not glasspacks), exiting out the rear with turndowns.
Lotsa Jeeps...
One Bronco...
tobyw is offline   Reply With Quote
Old 10-03-2006, 08:04 AM   #5 (permalink)
yjw/350's Avatar
Member # 67443
i found these, will they work for my application??
http://www.holley.com/2300HKR.asp
90 YJ SOLD
FOR SALE or TRADE
Old 10-03-2006, 10:28 AM   #6 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
everyone i know with headers has major leak issues. stick some manifolds on there that fit where you want them to dump, then go to the local exhaust shops after they close. a lot of times they leave all kinds of scrap lengths and bends outside for garbage. weld it. done.
rob
[URL="http://www.tr-motorsports.com"]TR Motorsports #108[/URL]
87JeepWrangler is offline   Reply With Quote
Old 10-03-2006, 11:16 AM   #7 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
Another vote for RAM horns, and crossover pipe-run single exhaust-one less muffler and pipe to bend. You can get the corvette ram horns that have a 2.5" mouth instead of 2.0". But-we are not building racecars or diesel pulling trucks-exhaust diameter is not important as people think unless you get under the 1.75/2" range and crimp it shut on a rock.
actionpaintball is offline   Reply With Quote
Old 10-03-2006, 11:38 AM   #8 (permalink)
jwag's Avatar
Member # 7638
Send a message via AIM to jwag
Hooker Blockhuggers and custom made exhaust using 2.5" U bends. On a CJ but you get the idea
A pic of the headers
jwag is offline   Reply With Quote
Old 10-03-2006, 11:56 AM   #9 (permalink)
G.C. Bandit's Avatar
Member # 3237
Send a message via AIM to G.C. Bandit
Stock manifold. Drivers side comes down and goes inbetween the oil pan and where the tranny bolts up.. Kept it up as high as possible and then meets into the pasagers side and that then goes into a single chamber flowmaster.
TJ/Wrangler MUTT...
Dana 80 37 Spline, Discs :)
Bling HP60 Dendenbears,Chromos/Longfields FULL HYDRO 47LTB's Locked with C&R BreadLocks 350TBI Sm465 203-205 Gen2 Doubler
[SIZE="5"][B][COLOR="Blue"]ROCKZOMBIES4X4.com[/COLOR][/B][/SIZE]
R.I.P. Dave "Kyle"
That was one hell of a ride, I will never forget!
G.C. Bandit is offline   Reply With Quote
Old 10-03-2006, 12:08 PM   #10 (permalink)
Member # 73664
LT1...Edelbrock headers into a combo of stock/custom Ypipe into a single 3" Flowmaster.
Z28YJ is offline   Reply With Quote
Old 10-03-2006, 01:38 PM   #11 (permalink)
chumly2071's Avatar
Member # 8293
Send a message via AIM to chumly2071 Send a message via Yahoo to chumly2071
I've seen a couple mentions in searches of people using a '66 chevy c10 application for a y pipe from napa... anyone here have any first hand experience and/or pics of this installed?
I'm running shorty headers witha 2" crossover, into a 2-1/2" single exhaust to a flowmaster. I haven't run this rig on the trail yet, but the underhood heat is a big enough issue that I am going to swap out the headers for a set of rams horns and reconfigure my crossover pipe.
I'm an Engineer. Why leave it alone, when I can REALLY screw it up?
There is no mechanical problem so difficult that it can't be solved by brute strength and ignorance.
chumly2071 is offline   Reply With Quote
Old 10-03-2006, 01:59 PM   #12 (permalink)
jesster's Avatar
Member # 49468
I have been running Hooker blockhuggers for several years now. However, after several trail runs since I put in new poly motor mounts on my AA cradle, I have noticed that the poly is melting.
Now, I am thinking about changing over to ram horns in order to get rid of some of the heat.
For those running ram horn manifolds in a Jeep, are there any fitment issues with the center dump type, or are the 45 degree rear dump type a better fit for the application? I figure the straight down center dump type will be easier to modify to replace my current blockhuggers, which dump straight down.
I will be using MORE bombproof weld on motor mounts when I redo my exhaust if that makes a difference.
jesster is offline   Reply With Quote
Old 10-03-2006, 02:05 PM   #13 (permalink)
Brian1's Avatar
Member # 2205
I run Summit Racing block huggers. I run a 2.25" (I think, I had it done by a shop) pipe under the oil pan from the pass side that joins up to the driver side and then turns into a single 2.5" out through a Flowmaster 50. My headders are wrapped and I havent had any issues with melting poly engine mounts, heat killing my starter or exhaust leaks as of yet.
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote
Old 10-03-2006, 02:13 PM   #14 (permalink)
Member # 28566
I love how guys get their first taste of how crappy headers are, and ask what kind of headers will solve their problem.
That's kind of like falling asleep and hoping that the ugly woman sleeping next to you will be beautiful when you wake up in the morning.
Old 10-03-2006, 05:32 PM   #15 (permalink)
LCAC_Man's Avatar
Member # 35307
Won't disagree that the cheapy headers will always be a problem but there are quality shorty headers out there that (when installed properly)will seal every bit as well as a cast manifold. They are usually twice the cost but as with everything else on your rig YGWYPF.
Also agree that the woman will not get better looking regardless of the level of hoping. I just divorced her and upgraded to a newer more cosmetically pleasing model.
Len Barron
72 Commando/LS2/4L65e/NP241
DRWHP60-ARB/14B-Detroit/4.56/H1's/37's
Bullnose Build in Progress
Stretched Bullnose
LCAC_Man is offline   Reply With Quote
Old 10-03-2006, 05:42 PM   #16 (permalink)
Member # 25424
I also hate headers offroad. I run the Corvette manifolds, love em.
When your down to one wheel drive pull the cable.........or back up and give it one more try!
SEEJAY7 is offline   Reply With Quote
Old 10-03-2006, 07:14 PM   #17 (permalink)
Member # 1636
I also have Hooker blockhuggers and I also melted a few sets of poly mounts on the AA cradle. So did another guy I wheel with who has these headers and motor mounts. I eventually changed to the AA weld-on style mounts (needed to raise my engine to clear the hydro steer ram) and haven't touched them since.
Check the end of my build thread for exhaust pictures.
chris demartini is offline   Reply With Quote
Old 10-03-2006, 09:22 PM   #18 (permalink)
j5
Member # 52063
I run the vette ramhorns with the 2.5" dump on mine. The right exhaust I bring under the front of the oil pan and collect it near the starter. I then go 3" all the way out by the left rear wheel well. I've got 2 cats and a muffler crammed in there on my 5.7 vortec so it can be done. You should be able to tuck a full sized flowmaster in there.
88 YJ over budget
49 willys m100
j5 is offline   Reply With Quote
Old 10-04-2006, 06:10 AM   #19 (permalink)
chumly2071's Avatar
Member # 8293
did some more searching, and found this in the 'yota forum...
http://www.pirate4x4.com/forum/showt...731&highlight=
Old 10-04-2006, 07:27 AM   #20 (permalink)
Gunmetalcruz's Avatar
Member # 6569
hooker headers, 2 1/4 inch u bends from summit for cross over then 2 into 1 then 3 inch into a dynmax bullet with turn down. Wrapped with exhaust wrap to cover the shitty looking exhaust welds and chop saw cuts and for the heat on the floor boards
Team FOH# 321
Thanks to the people making it happen
Weathertight,Polyperformance,CTM Racing Products,Levrett Transmission,BFGoodrich Tires,Kickass Offroad,Reid Racing,West Coast Differentials,Wide Open Design
Gunmetalcruz is offline   Reply With Quote
Old 10-04-2006, 07:39 AM   #21 (permalink)
jesster's Avatar
Member # 49468
I remember you saying that they wouldn't last when I first put the poly mounts on the cradle... And you were right.
Those AA weld ons seem to place the bushing farther away than most... I think that I may take your advice and go this route.
Thanks,
Jesse
Old 10-04-2006, 08:02 PM   #22 (permalink)
BossBuilt's Avatar
Member # 1760
Wow!! All this crap and not one word about slick-fit block huggers???Just look for headers with a 3/8" or thicker flange and you won't get the infamous leaks...Slick-Fit has a compact design that pretty much stays out of the way.....and has a nice 3/8" flange.......good luck with your choice....sounds like the rams horns are the coat-tail of the month,haven't tried them but it sounds like an option.
Sent from my ASS, via shit-de-phone.
BossBuilt is offline   Reply With Quote
Old 10-04-2006, 08:06 PM   #23 (permalink)
jchio's Avatar
Member # 34
Send a message via MSN to jchio
Hedman fenderwell hedders, I think they were "in" 10 years ago.
Im going to block huggers to keep the whole exhaust under skidplates..
[URL="http://www.Jeeperos.com/foros"]Jeeperos.com[/URL]
Well, the guy wants to run for president, he thinks Moby Dick is a venereal disease.
jchio is offline   Reply With Quote
Old 10-05-2006, 09:42 AM   #24 (permalink)
Member # 74772
Send a message via AIM to 82'CJ7
I called Summit last night..they have the ram horns for 69.00 a piece. Will take 2 weeks to get in. We are starting our 350 swap this weekend into the CJ7.
THE NEVER ENDING 72'COMMANDO PROJECT
82'CJ7 is offline   Reply With Quote
Old 10-05-2006, 05:48 PM   #25 (permalink)
shelljeep's Avatar
Member # 7352
Got an early 90's 350, what year Vette manifolds should I be looking for?
Does it have to the same era?
Won't most of the years interchange?
Always workin' on it or at it.
shelljeep is offline   Reply With Quote
