Which electric fuel pump?
1987 YJ, 4.2/auto
I've decided I'm going with a new fuel pump, this time electric to avoid the constant failure of the mechanical type that I keep having to replace. Also, it should help with the hard-starting Weber I have on there. So, what type should I look for, in terms of volume, PSI, etc? I'm assuming a pressure regulator is now in order? Street should be 3.5# or so, what about offroad? Any brand you guys have used and are happy with? Price range? TIA |
Member # 9994
are you using the return line on your fuel system? i believe this causes mech. pumps to fail since they are constantly being dead-headed. i have a NAPA special electric fuel pump on my scrambler. its the square gold one. they carry one thats higher pressure (up to 14 psi) and one thats lower (around 8 i think) i have the lower pressure one for my AMC 360 V-8 with Q-jet carb. matt
1984 CJ-8 1986 CJ-7 1981/1992 CJYJ 1994 RAM 1500 4x4 Custom Fabrication Parts: [url]www.troutindustries.com[/url] |
Thanks for the reply, matt. About how much did that run ya?
I am using the return line, I wasn't aware that it could damage the pump (never really thought about it). I've gone through about 4 pumps in the last 6 months (some of them have been defective out of the box; I now test them at the store. BWD sucks). Is there a blockoff plate for this engine (I6), or will I have to make one from stock? |
#4 (permalink) | |
Member # 5577
It's all here before your eyes / Safety is a big disguise / That hides among the other lies |
Member # 9994
on mech pump failure: i think they will fail more frequently if used without a return line.
as for the electric pump, its this one: http://www.napaonline.com/cgi-bin/nc...grpid=30086379
Thanks for the link, matt. I'll check out the pump at the local Napa.
But ya got me a bit confused: you think mechanical pumps should or should not have a return line? I've never thought that having one would damage anything, but maybe I was gonna learn something new here?
Member # 8108
I bought this one
It seems like a beefier unit and has worked very well on my Blazer. Good luck.electric fuel pump
AtoZ Fabrication, Inc. 570-385-3931--shop 570-385-3932--fax MADE IN AMERICA---and proud of it!!! We also offer the best service and prices available on: Advance Adapters Clayton Offroad Suspension Raceline beadlocks wheels Amsteel Winchline and accessories ORI struts and Radflo shocks Read my story about Todd at F&S Racing in the Bad Sellers forum Last edited by zachv; 05-02-2002 at 08:18 PM. |
Member # 8913
How did the other pumps fail? Rember that electric pumps do not suck well,they push well.When running an electric pump you should run a relay hooked up to an oil pressure switch,in case of a roll over.Electric pumps should be mounted as close to the tank as posible.Also fuel return lines help keep fuel cool and cut down on vapor lock.
The other pumps failed because, well , they stopped pumping gas ... Can't really tell you much more, other than that when removed, they had no sucking power whatsoever. From one day to the next (always overnight, would try getting the Jeep running the next day and there'd be no gas).
The last one had to be "primed" several times before it worked, though it had suction and there was plenty of gas in the tank. I haven't had any problems with it yet - but it's only been in for a few weeks. The new pump will be mounted on the frame rail, but first I have to get a new frame, LOL ... mine's so bad there is no place to drill two holes. The new frame goes in in two weeks. The new frame comes with new gas lines, so if the problem is in my lines, that'll be resolved as well (I've never found any cracks or leaks, or kinks, and otherwise the Jeep runs fine). Thanks for all the help, folks. |
