14b disc brake conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-19-2006, 05:48 AM   #1 (permalink)
Member # 55027
So I have been using the 14b tech section on Pirate4x4 to do my disc brake conversion for my 14b swap into my Waggy and had a question I hope you all can answer.
In the article, it is mentioned that the stock lugs can be used in the new setup but because of the large round head of the studs not quite fitting into the 3/4 ton rotors the lug nuts just barely engage the studs. BillaVista says that the alternative is to source out new studs that will work and says he will add the info later, but it is never mentioned again. Is there an alternative stud to be used that works with the 14b and 3/4 ton rotor so the lugs will engage better?
As in the article, this is going on my trail Jeep only so I could just reuse my studs, but if I can get a better part for the job, I would rather do it now rather then later since I have it apart.
Sorry if this is newb, but figured 3/4 ton swaps were a little more this forums expertise.
Rick1975 is offline   Reply With Quote
Old 10-19-2006, 08:30 AM   #2 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
this was covered a few times already. if i remember correctly, the verdict was that it depends on which year your axle is. for some people, they could use the stock studs, and on others, it didnt work. in mine, it worked fine, but i also dont know what year my axle is.
rob
[URL="http://www.tr-motorsports.com"]TR Motorsports #108[/URL]
87JeepWrangler is offline   Reply With Quote
Old 10-19-2006, 08:38 AM   #3 (permalink)
Hammered Scout's Avatar
Member # 62561
I put mine on lathe and turned the head down enough to seat in the recessed hole of the rotor.
69 Scout 800, 60F,14bolt,6.0 LQ9/T400/Atlas4.3,39.5 Swampers, 2001 Dodge CTD 6Spd H.O, 4x4, 1965 Unimog
[SIZE="4"]"If your buddie was shot in the ass with diamonds, coils and 4 link would be the way to go IMO." [/SIZE]
Hammered Scout is offline   Reply With Quote
Old 10-19-2006, 11:14 AM   #4 (permalink)
Member # 24640
On mine the stock studs worked fine, there is maybe a little less than a 16th around the outside of the head of the stud, my axle is out of a '91...at some point (I don't remember exactly '88ish maybe, the 14b bible says) the drum/hub arangement was changed to allow drum removal without removing the hub. At some point along in there they also switched to metric studs, but I think that there were a couple of years with the later stud that wasn't metric threaded. I suspect that the stock studs for the later style drum/hub are the ones that have the right heads. I say that just cause I was able to use the stock style stud from my drum settup on my disk setup. Just an idea you might want to get ahold of one and measure it to see if it will work.
Co-Driver 4447 Camco Rock Racing
Thanks to our partners: Bulldog Winch, Jackson Powertrain, Winchline.com, BFG, Raceline wheels
jmhinescj is offline   Reply With Quote
Old 10-19-2006, 01:21 PM   #5 (permalink)
Member # 498
Send a message via ICQ to WheelingPiazza Send a message via AIM to WheelingPiazza
On mine the stock studs were to short and didnt offer enough engagement on the lug nuts for my liking.
I will make it easy for you.
1973 chevy k20 3/4 ton p/u 4wd rotors
716779 5523 567 12.5" Rotors
Wheel studs
DOR 610-189
KI6PZZ, One of the wheelingpiazzas.
Dysfunctional Rockcrawlers (TDO)
WheelingPiazza is offline   Reply With Quote
Old 10-19-2006, 02:21 PM   #6 (permalink)
Member # 55027
Thanks Pizza, but about an hour too late...hehe. I just got back from Autozone and got the right wheel studs on a guess...hehe.
Old 10-19-2006, 02:34 PM   #7 (permalink)
vintagespeed's Avatar
Member # 25551
Send a message via AIM to vintagespeed Send a message via Yahoo to vintagespeed
I went to Pepboys and went thru their studs they keep in the back...
Found a perfect set and robbed all the neighboring stores of them to make a set.
Is this really advanced tech?
-jb Stop Islam Now, preserve America for Americans
vintagespeed is offline   Reply With Quote
Old 10-19-2006, 03:04 PM   #8 (permalink)
mxracer33x's Avatar
Member # 43110
Friend just documented his 14 bolt swap studs i nthe IH forum
Dorman part numbers
mxracer33x is offline   Reply With Quote
Old 10-20-2006, 04:27 PM   #9 (permalink)
Member # 52752
where did you get the wrench to remove your spanner nuts off the 14 bolt? NAPA, Checker, nor Advanced in Laramie Wy have any fucking clue what I am talking about.
thanks
micky
bowtied_micky is offline   Reply With Quote
Old 10-20-2006, 04:48 PM   #10 (permalink)
Member # 77602
I used a screw driver and a hammer. But I would like to get one to tighten it to torque specs. Can u use the same one for a Ford D60?
Blue1TonYJ is offline   Reply With Quote
Old 10-20-2006, 05:14 PM   #11 (permalink)
Member # 15322
I got mine from snap on, I can look for the part number tonight for you guys.
YJ7, 5.3L, TH350, 231/300, D60f, 14Br, SOA Front on 2" BDS w/ Relocated hangers, 4link Rear, 4" total lift, 113" WB, caged, armored, 44" Pitbull Rockers, slowly but surely, getting closer to being done.
2011 GMC Sierra Z71, the DD
YJ4rocks is offline   Reply With Quote
Old 10-20-2006, 11:52 PM   #12 (permalink)
Member # 25551
It's a six point 1ton hub socket. Got mine at vAutoZone. You should be able to get one anywhere.
Old 06-08-2007, 06:20 PM   #13 (permalink)
Member # 45530
I know this is an old ass thread but I pulled it up while searching, went a few pages further and still didn't find my answer
I fubar-ed my stock lugs on my 14 bolt and was going to order some new ones. Since I"m pressing hubs onto rotors would the front studs from a 77 K20 work, or do I need to get the factory rears and use those?
Panthers65 is offline   Reply With Quote
