2+ year TJ build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-25-2006, 08:02 AM   #1 (permalink)
#678
sommertime's Avatar
Member # 20569
2+ year TJ build stretch,cage,engine,dash
I figured that I would finally post a buildup thread. Started with a rear stretch.
I cut the frame just behind the body mount under the doors and had a metal fabricator break me some 1/4" wall c-channel to fit over the frame snug. I braced the frame to keep it square before I went to cutting
The CB pimp!! Jim's Garage #17
sommertime is offline   Reply With Quote
Old 10-25-2006, 08:05 AM   #2 (permalink)
#678
sommertime's Avatar
Member # 20569
This was my finished wb............not the correct ride height.
I eliminated the track bar and heres how the control arms lay
Old 10-25-2006, 08:15 AM   #3 (permalink)
#678
sommertime's Avatar
Member # 20569
You can also noticed that I upgraded my camera too!!
Finished the stretch and here is the corners and CJ hinged tailgate
Then it was time for the cage and new PRP seats
Had the same metal fab guys build me a sheet metal box with a lid to fit the factory fuel tank
Old 10-25-2006, 08:19 AM   #4 (permalink)
#678
sommertime's Avatar
Member # 20569
Then we get finally finished with the seats, cage, stretch, corners fuel tank and this is what I ended up with..........but i couldn't stand it running and ready to wheel.....more to come.
Went on 3 trips
Clayton twice Nocona once
Old 10-25-2006, 08:20 AM   #5 (permalink)
Moderator
geberhard's Avatar
Member # 5861
I like the setup, I did a similar tank move up and box, but did not go so high. Your build is coming out pretty cool! I think the front hide height is lower because of all the stickers Gotta balance some to the back. JK!
Good work!
geberhard is offline   Reply With Quote
Old 10-25-2006, 08:24 AM   #6 (permalink)
Member # 31158
What axles are you running? The rear looks like a 9".
Nice jeep man.
Joel77 is offline   Reply With Quote
Old 10-25-2006, 08:28 AM   #7 (permalink)
Cue
Cue's Avatar
Member # 28682
Yes very sweet project.
Dirk
www.4x4oil.com
Your #1 Source for Amsoil Lubricants
Lube it or Loose it!
facebook
CHECK OUT THE AMSOIL COST +$5 SALE HERE
Cue is offline   Reply With Quote
Old 10-25-2006, 08:42 AM   #8 (permalink)
#678
sommertime's Avatar
Member # 20569
The rear is a 9" with hd tubes, 35 spline molly axles, nodular case 5.13's The front is 60/9 hybrid all molly with 35 spline. 42's/104" wb in the picture.
Old 10-25-2006, 08:46 AM   #9 (permalink)
#678
sommertime's Avatar
Member # 20569
I can't leave out my cheap ass tube bender
I can't take any of the credit for the engineering of this lets just say it was a handed down secret.
Old 10-25-2006, 08:50 AM   #10 (permalink)
#678
sommertime's Avatar
Member # 20569
Lets get to this year..........well after the 3 trips I took on the new rig/tires the ole 4.0 with 176,000 miles just really wasn't liking the upgrades.
Time for some displacement
LT1/4l60e
Old 10-25-2006, 09:11 AM   #11 (permalink)
#678
sommertime's Avatar
Member # 20569
Since I am going to put my rig down for a while might as well add some stuff to the plate.
Stretch the front 6" to get a 110" wb
full hydro and flat dash!
Move the coil buckets 6" forward
Old 10-25-2006, 09:16 AM   #12 (permalink)
#678
sommertime's Avatar
Member # 20569
Move the track bar behind the axle and shorten the track bar to fit
Add length to the RE control arms
I already had the fabbed in for my hydro-assist just got to make sure the 2.5"
ram fits
And add some bling
Old 10-25-2006, 09:21 AM   #13 (permalink)
#678
sommertime's Avatar
Member # 20569
Now for the flat dash........this was a virgin pic I have changed my mind about 20 times but you get the general idea. I pulled the stock column and just did a quick connect column straight to the steering valve. I also moved the whole dash up 3-4". Gonna be filled with Autometer guages and a 12volt guy ingition switch/winch control panel.
Old 10-25-2006, 10:23 AM   #14 (permalink)
ROCK & ROLL OFFROAD
Member # 3906
Send a message via AIM to Jeepmangled87
not to bad keep up the good work! Where you wheel at?
Jeepmangled87 is offline   Reply With Quote
Old 10-25-2006, 12:39 PM   #15 (permalink)
desertsport's Avatar
Member # 39627
[QUOTE=sommertime]
Can yuo give some more info on your extended control arms, it somthing I considered for the future.
Btw the way, your build looks nice.
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56
desertsport is offline   Reply With Quote
Old 10-25-2006, 01:37 PM   #16 (permalink)
Ford_KTM's Avatar
Member # 49754
you're useing a 2.5 with hydro asist?? What box and pump are you using??? Won't it steer really slow with the 2.5?
Ford_KTM is offline   Reply With Quote
Old 10-25-2006, 01:54 PM   #17 (permalink)
Member # 48100
Nice build. Is that an RE track bar cut down?
2008 Jeep Unlimited X
My 1 ton TJ Build [url]www.pirate4x4.com/forum/showthread.php?t=591360[/url]
tweba99 is offline   Reply With Quote
Old 10-25-2006, 03:13 PM   #18 (permalink)
Member # 21995
I'd like to see more pics of your dash as you get a chance
Looks good. I dig the 60/9 combo
mucknet is offline   Reply With Quote
Old 10-25-2006, 07:51 PM   #19 (permalink)
Member # 64636
yeah I'd really like to see more pics of how your dash is coming along... I have my jeep in a billion pieces right now and have kinda been tossing the idea about making a new dash for it around but not sure whether I wanna go that route or not
Tjeepfreak is offline   Reply With Quote
Old 10-25-2006, 10:20 PM   #20 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
Can you get more specific on the LT1 install?? I'm stuffing one in my rig too
ANDY<--- ME!
TrailWorthyFab.com<--- THE BEST DOUBLE BEAD LOCKS!
Project: Dookey's revenge<--- My Junk!
OFF ROAD GEAR<--COOL SWAG!
Old 10-26-2006, 04:20 AM   #21 (permalink)
#678
sommertime's Avatar
Member # 20569
I am a Clayton rat I like Hot Springs, I see you posting all the time on Cowtown. If you see me out........my name is Chris. Thanks btw
Old 10-26-2006, 04:22 AM   #22 (permalink)
#678
sommertime's Avatar
Member # 20569
NO full hydro/ PSC worked the LT1 pump and I installed a resevoir.
Old 10-26-2006, 04:27 AM   #23 (permalink)
#678
sommertime's Avatar
Member # 20569
I will post updates, its been a slow project due to the fact that I am a redneck and its hunting season
Old 10-26-2006, 04:31 AM   #24 (permalink)
#678
sommertime's Avatar
Member # 20569
I just cut the stock RE arms the short side and sleeved it with DOM I can't remember the exact size, I just went to Metal Supermarkets and fitted the control arm right there.
Old 10-26-2006, 04:42 AM   #25 (permalink)
#678
sommertime's Avatar
Member # 20569
Its a 96 LT1 from an Impalla SS, rebuilt the tranny. Sunray Engineering built the adapter its an awesome adapter call them they do these swaps everyday. Had LT1350.com work the harness and ECU talk about some fast awesome work, they eliminated all the VATS and added relays for ex fuel pump and cooling fans, and labeled the harness to finish wiring.
