WANTED: 4 Link Crossmember pics - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-27-2006, 01:14 PM   #1 (permalink)
rangerjoe2001's Avatar
Member # 37829
I need to see some examples of how people have made a crossmember for their lower arms on a Double Triangulated 4 link.
Whether you tied it into the Tranny crossmember or not, it doesnt matter.
rangerjoe2001 is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 02:21 PM   #2 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
I used 2x2x3/16" box tubing... I had it drop about 2 inches bellow the frame rails so I could get a decent roll center and more squat
Nordic1 is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 03:52 PM   #3 (permalink)
Member # 1636
Mine is 2x2 box welded to 2x2 angle iron which bolts to the factory skid holes. I also have plate welded on the inside of the frame rail that bolts to the 2x2 lateraly.
This is when I built it, I have since made the skin removeable. I still need to drop the whole thing to get the t-case or trans out, but I needed the lowers as long as possible.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 03:57 PM   #4 (permalink)
Member # 13886
Dude, if you're about to spend the cash it takes to build a 4-link, you should seriously consider buying a star. There's a wealth of information behind that search button.
71 Bronco frame off in progress.
efi302, 3 link front, 4-link rear
Buba is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 04:07 PM   #5 (permalink)
biggreentj's Avatar
Member # 36852
Send a message via AIM to biggreentj
good point, but i wouldnt buy a red star until they fix the search, i wish i would have known that.
biggreentj is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 04:18 PM   #6 (permalink)
Member # 37829
Yeah i am waiting till the search is finished...
The rear setup is gonna be $$$$$$
Old 10-27-2006, 11:31 PM   #7 (permalink)
Member # 19652
Send a message via AIM to socalchef
y'all got issues...search works swell for me.
socalchef is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 11:39 PM   #8 (permalink)
Member # 63225
Just some 1 1/2" tube and some plate.
TeenyCAR is offline   Reply With Quote Quick reply to this message
Old 10-28-2006, 04:01 AM   #9 (permalink)
Blown7's Avatar
Member # 63754
Having spent hundreds of hours searching this board and others, buying every suspension book out there, spending hundreds of hours designing my first double triangulated rear four link using a CJ7 aftermarket chassis now starting my front double triangulated link suspension, not having yet a running chassis to fine tune, nor do I consider myself being remotely close to being considered knowledgeable my observations are:
1. You have to define what vehicle it is going in.
2. You have to define what tire size your using.
3. You have to define the wheelbase, and if any stretch will be used.
4. You have to find a rough weight of the vehicle.
5. You have to state the axle width, and size.
6. You have to define the desired ride height.
7. You have to decide what modifications to the frame will be necessary.
8. You have to state what Transfercase is being used.
There are a few more parameters that need to be defined.
If this is not part of your question then your just window shopping for pretty pictures without any knowledge of what your seeking. The need to "see" what others are building are only applicable to them and their rigs only. Using the parameters that they had to design around.
I myself don't have a problem helping anyone but for me just to post pics for you to see without a few needed inputs from you, my pics are worthless to you.
Jeff
1977 CJ7, 401 AMC 6-71 GMC Blower, 16 Injector EFI,
[COLOR="Yellow"][SIZE="3"]My Build [/SIZE]
[/COLOR]
2007 Jeep Grand Cherokee SRT8 for the road.
Blown7 is offline   Reply With Quote Quick reply to this message
Old 10-28-2006, 09:08 AM   #10 (permalink)
Member # 63225
Pics are never worthless. If you find something you like you can always adapt it to fit your application. Pretty much all I look at is desert racing fabrication. Most of what they do would never fit a rockcrawler or even a 4wheel drive, but the principles are priceless.
Old 10-30-2006, 09:59 AM   #11 (permalink)
P&T Jeeps's Avatar
Member # 3916
the entire build can be found here: /forum/jeep-hardcore-tech/274444-tj-rear-frame-stretch-1-tons.html
but here is a pic of the crossmember b/f it went in:
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
P&T Jeeps is offline   Reply With Quote Quick reply to this message
Old 10-30-2006, 11:56 AM   #12 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Mine was a cross member but the new doubler was so long I need to keep the bottom open.
Pictured withought the second T-case mounted:
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 10-30-2006, 08:32 PM   #13 (permalink)
Member # 47905
x2
82' cj-8 in peices GM 6.0 NV4500 D300 GM D60 C14
Bowtie Binder is offline   Reply With Quote Quick reply to this message
Old 10-31-2006, 03:16 AM   #14 (permalink)
Blown7's Avatar
Member # 63754
Originally Posted by Bowtie Binder
x2
So he's running a Matkins frame? (All carved up) Quadratrac? Waggy width axles? 80 percent antisquat? 1 1/4" Heims all the way around? A 3 inch tranny/engine chassis drop? 5 inch rear stretch? 16 inch SAW's? ) 0 degrees over/understeer? 107 inch wheelbase? 35 inch tire diameter?
All this affects the crossmember design.
He's mine for what it's worth
Jeff
[/COLOR]
Old 10-31-2006, 08:44 PM   #15 (permalink)
Member # 47905
Jeff
I doubt if he had this setup he would be asking for pics
Old 02-13-2013, 09:00 AM   #16 (permalink)
Penguin
theRockHopper's Avatar
Member # 209848
Two mounts on the crossmember two on the frame.
HIDE
HIDE
Despite the high cost of living... it's still quite popular.
theRockHopper is offline   Reply With Quote Quick reply to this message
Old 02-13-2013, 01:00 PM   #17 (permalink)
:flipoff:
rob low's Avatar
Member # 98084
Your 7 years late.... Tell me you haven't been waiting 7 years to post that pic.
Your a real breath of fresh air.
face="Comic Sans MS">My build:
rob low is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 09:40 AM   #18 (permalink)
Penguin
Member # 209848
g@d.. dam.. f*ck'n.. sh!t.. I'm such a newb.
I need to start looking at those dates more.
HIDE
HIDE
