Member # 4361
Problems with running wider tires?
Im thinking of moving to a 38x15.50, and wondered what problems to expect from a tire that wide. I havent ran wider then a 12.50 before.
Jeep #1:[url="http://rockcrawler.com/readersrides/display_netscape.asp?ID=2656"]TJ With 35" tires, Ford 9" axles, 5.67 R/P, Tera Long Arms, Detroit Lockers, 12K T-Max winch, and much more. Click here for mods and pics[/url] Jeep #2: 94 XJ, 4L, Stock. The DD. Jeep #3: 06 WK, 3.6L, Stock, The Woman's. |
#4 (permalink) | |
Member # 4361
Why is that? I can see other steering components having problems, but I dont see why the balljoints would? I do have larger balljoints on my front 9", but they arent that much better then the dana 30.
Depending on the tire, rim and suspension choice you may have to limit your steering. If you have outboarded leafs or links that sit wide on the axle and run something like a Bogger with big side lugs, the lugs may grab your leafs or links when turned. A simple fix is to adjust out your steer-stops on the knuckle.
-Kevin Last edited by KKno; 10-28-2006 at 07:18 PM. |
