Dutchman Axles... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-08-2006, 01:30 PM   #1 (permalink)
Member # 74066
Dutchman Axles...
Need to get some new shafts to upgrade my rear Dana 44 in my CJ-5. It has the passenger offset diff, so I need to order custom shafts as nobody has them in stock. One vendor can get me some Dutchman 30 spline flanged 1541 shafts for $440 with bearings and all, which is generally a little steep, but they aren't commonly stocked axles. I'm wondering, are Dutchman axles good, or are Alloy USA better? I've heard mixed results recently on Yukon. I haven't contacted Yukon or Alloy yet, though. Anyone have any suggestions, are the Dutchman just as good as Yukon and Alloy? I don't want to wait for Superior. Thanks.
'92 YJ, 4.6 stroker, dana 300 w/4:1, 60's, 5.38's, detroits, 101", 40" MT/R's, KMC Beadlocks
SkysTheLimit is offline   Reply With Quote Quick reply to this message
Old 11-08-2006, 02:05 PM   #2 (permalink)
Member # 25360
I would not buy Dutchman nor recommend them to anyone. A friend of mine bought a set of custom 30 spline axles for an International D60 rear. We put them in and took it out to a ride and on the first obstacle twisted the splines on one side and the other side broke off right at the mounting flange so clean that you would never know it had an axle attached. All of this also took out the Detroit. Dutchman would not warranty there axles at all. They said it was because we had them in a rig with 42's on it. Keep in mind that the stock axles lasted two years on this same setup.
I would not consider Dutchman at all.
1989 Wrangler -- Working on it
- 6.0 LQ9
- TH400
- AtlasII 3.0
- Ford D60's w/ 5.38's (chromo 35spline throughout with rear ARB)
- 39" Red Labels
BamaScout is offline   Reply With Quote Quick reply to this message
Old 11-08-2006, 02:07 PM   #3 (permalink)
crawlin'YJ's Avatar
Member # 7958
I have dutchmans in my rear 35spl. 60, no problems at all, they've held up great.
crawlin'YJ is offline   Reply With Quote Quick reply to this message
Old 11-08-2006, 02:44 PM   #4 (permalink)
Rubicrawler's Avatar
Member # 2037
I've never ran 30 spline axles but I've had great service from Dutchman! I had 35 spline Dutchman's in my old EB 9" with a Detroit and 39.5 Iroks and I now have them in a rear HP D60 with a Detroit with 42" TSL's and approx 380 HP. I just got back from flogging it through the Hammers and they held up great! I'd recommend them
Mark Langford
KI6TMK
'86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's
Dysfunctional Rockcrawlers (TDO)
Wheelers for the Wounded of California
Rubicrawler is offline   Reply With Quote Quick reply to this message
Old 11-08-2006, 03:00 PM   #5 (permalink)
jpcrawleram's Avatar
Member # 18734
I have had great luck with dutchmans as well. I have 3 of their shafts in my rig and no issue with any of them. Price is usually right on as well. Cheaper then Moser atleast
LetzRoll Offroad / LetzRoll offroad Racing 4493
480 797-0469
All your Hardcore Crawling / Racing needs!
PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon gear and axle, Reid racing, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec), Rock Krawler, Artec Industries, ADS racing shocks, Rugged Radios
jpcrawleram is offline   Reply With Quote Quick reply to this message
Old 11-08-2006, 03:51 PM   #6 (permalink)
B.A.R.K's Avatar
Member # 8540
Why dont you ask this guy.
/forum/jeep-hardcore-tech/522904-shafts-d44.html
He already posted the same question for you. He should be a great help.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 11-08-2006, 05:14 PM   #7 (permalink)
Member # 74066
Thanks guys. It sounds like most people are happy with their Dutchmans, except the first dude. I'm only running 33's, 1.25" wheel spacers, and the Dana 44 is obviously not full float, so I need to run 1541 shafts instead of 4340, so hopefully these shafts hold up okay for me. I figure they should be better than the 19 spline two-piece stock shafts, right? Maybe I'll just check with Dutchman on their warranty and see what they say and go from there. It would be nice to have a product with a warranty. Also, they are only about 2 hours from me, so that kinda helps in the bitch-fest should one arise in the future. Anyone else, please still pipe in with your advice, too. Thanks.
Old 11-08-2006, 05:36 PM   #8 (permalink)
Member # 44579
I ordered custom 6 lug shafts for an XJ 44.
I ordered from Dutchman because they were the most helpfull when taking my measurements. The fabricator actualy called the day he was putting them together to verify specifics.
I guess I'm more about customer service when I'm spending excess money.
[b][ ] [u]l l l l l l l[/u] [ ][/b]Save your money for gears and swampers then save money on your lift by cutting out your fenders.
TACH329 is offline   Reply With Quote Quick reply to this message
Old 11-09-2006, 10:30 AM   #9 (permalink)
Member # 18320
I was in your shoes a few years ago. I had a 30 spline offset D44 rear. When I found out that only custom shafts were available for it, I decided to upgrade to a 60 rear with 9" ends & dutchman 35 spline shafts.
If you have a 19 spline carrier, you will have to change that out to go to 30 spline. If you have to change out the carrier, I would upgrade to 35 spline axles. The shafts would be similar in cost, and would be nearly indestructable with 33" tires.
When I put the 60 in, I figured I could recoup some funds by selling the 30 spline axle shafts out of my 44. I had them sold on here for a nice price. When I took them out to ship, the splines were twisted. At the time, my CJ5 had 35" tires. I am glad I spent a little extra & went with the added beef.
elarsen is offline   Reply With Quote Quick reply to this message
Old 11-09-2006, 11:21 AM   #10 (permalink)
Member # 2037
My best advise to you is don't build your axle to meet your current tire size and need. Your 33's will be replaced by 35's then 37's etc. Build it once and build it right. A nice set up for your Jeep would be a Ford 9", Strange Nodular Housing, Detroit w/35 spline axles. This set up would allow you to build your Jeep up and give you years of trouble free service It may be more $$$ now but a lot cheaper in the long run
Mark Langford
KI6TMK
Old 11-10-2006, 09:09 AM   #11 (permalink)
Member # 74066
I know what you are saying, and I'm trying to not build it for 33's, I would like to know I will be more than safe with 35's, since I see that as my next logical step. I say this because after 35's, I would save cash and do SOA, X-Over steering, and I would run 60 front and 60/70/14b/10.5Sterling rear axle, whatever I found, stretch the wheel base, and then run the appropriate tire for the lift and axles after it is all built, which would be in the 38-42" range. So, right now 35's is all the bigger I will go with these axles, that's a guarantee. So I now have a couple questions, is a 33 or 35 spline shaft larger in diameter than a 30 spline shaft, cuz if not, I'll run the highest spline count I can since I need to get a new spool for the whole encounter anyway, and is a 30, 33, or 35 spline flanged, semi-floater, 1541H shaft gonna hold up well enough. I wanted to get the warn full floater kit and run 4340, but they discontinued it, so I'm stuck with a semi-
Old 11-10-2006, 03:45 PM   #12 (permalink)
CHOKEu's Avatar
Member # 7954
Send a message via AIM to CHOKEu
Have had my 35 spline shafts for 6 years now... No problems!
KEVIN
aka CHOKE
TJ-60's-ATLAS-37's-104" wb- Full Hydro-Turtle Wax
Vertical- up seperates the "Welders" from the Rodburners"; welding out of position, in restriction, on pipe, with a mirror, seperates "YOU" from the "Welders"!
MY JUNK-
CHOKEu is offline   Reply With Quote Quick reply to this message
