Ford 9" disk brakes. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-19-2006, 11:03 PM   #1 (permalink)
Member # 64625
I've been lookin all over the board here, in all forms of search engines and whatnot recently trying to find the "formula" to get disk brakes on a 9" without having to buy those stupid currie spacer bearings, bolt on backing plates, or machining down the axle flange to fit in the rotor. However I have been unable to do so.
So I went out got a Brembo book of parts and went to work. After $498 in returns I found the combo that works.
First thing was using BTF (or any brand) 1/2 GM weld on brackets and '78 k10 GM 1/2 calipers. Then finding the correct rotor. This was the pain in the ass part. Trouble is finding a rotor with a wide inside register, but also with a very deep hat so the 1/2 ton caliper will fit inside a 15" rim. And the ONLY rotor that fits this description is a 2001 Dodge Ram1500 4wd front rotor.
Then i just used 3/16" hardlines and drilled out some front jeep brakelines so the GM banjo bolt would fit. All in all i went through 9 rotor combos trying to get this to work and was a major PITA.
*note: depending on what type of 9" you have, you may have to grind 1/8" out of the diamter of the caliper bracket before you weld it on.
FoxinBox is offline   Reply With Quote Quick reply to this message
Old 11-19-2006, 11:46 PM   #2 (permalink)
Banned
Member # 68805
And to think you could have just gone to TSM and gotten their kit. What's wrong with bolt-on backing plates?
TJVigilante is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 10:16 AM   #3 (permalink)
CRAWLTHIS's Avatar
Member # 33341
Or you could have spent < $75 at the local pick and pull and grabbed some
'99 Ford Explorer rear disk brakes with the parking brakes built in. Depending on what bolt pattern you have which relates to what axle bearing you have (small, large Ford) you might have to modify the bracket a little, but if you are running 5 on 4.5 bolt pattern it will all bolt on.
[B]"It's like a swore peeder, you can't beat it!"[/B]
'90 YJ, TBI 350, SM-465, hi609, Ford 9" 5.13, and 36SX's
CRAWLTHIS is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 10:27 AM   #4 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Or buy the whole kit new for 350.00:
Part #M-2300-G
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 12:36 PM   #5 (permalink)
Member # 1763
Send a message via AIM to Grnscru
Part #-2300-G
Company with the above kit?
97 TJ - 5.13's, 9" Detroit, HP44 ARB, 36" TSL's
06 F350 - Towing Duties
Grnscru is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 12:43 PM   #6 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Just google M-2300-G! It's from Ford Motorsport.
BUY MY BOAT
Old 11-20-2006, 01:04 PM   #7 (permalink)
MC
Nose to grindstone
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
What about the Nissan caliper (With parking brake) and Suzuki rotor? Their is a vendor that sells brackets here.
MFGS of the STAR-LAB CNC machines
The finest CNC plasma tables
Made in the USA by Bulltear and can be found online at
and at local welding stores
Hypertherm and Thermal Dynamics
We also make parts for AMC
MC is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 01:32 PM   #8 (permalink)
Hendo's Avatar
Member # 20295
Send a message via MSN to Hendo
l have them on my ford rear , they dont work that good with my 42,s
i would look at useing atleast a 1/2 or 3/4 ton set up, the e brake is nice but theres somebody has a e brake built into the caliper
Hendo is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 05:56 PM   #9 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Kind of worthless info without the bore size of your M/C!
BUY MY BOAT
Old 11-20-2006, 09:33 PM   #10 (permalink)
Member # 64625
Well true... i could have spent 300 and gotten a kit....
Or i could have spent $140, gotten large 1/2 ton calipers, huge vented rotors, and then post it up for other people to use since I have yet to see a person posting a rotor that has a deep and wide enough hat to use.
And i dont want using a bolt on bracket so i dont have to go to currie everytime i want to buy a special .100 wider bearing.
So for all you saying its not for you... shove off.
Old 11-20-2006, 09:38 PM   #11 (permalink)
ItsaCJ6's Avatar
Member # 6340
So Asshats all listen and be wary dumbarse has a thought....
Had you presented a tech artcile instead of an "I am better that you " statement you might be further along in the karma scale than DUMBASS.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 11-20-2006, 10:49 PM   #12 (permalink)
bulfrog3's Avatar
Member # 11890
X2 They are great.
bulfrog3 is offline   Reply With Quote Quick reply to this message
Old 11-21-2006, 07:05 AM   #13 (permalink)
Stowe's Avatar
Member # 32704
Send a message via Yahoo to Stowe
Get a RED STAR and search...this has been covered at least 20 times and broken down to how to get everything for around $100. Great job ace!
'89 YJ, 347, C6, NP205, D44, TruHi 9, 35's ->Burnt up by Meth Heads.
'05 LJ - Bone stock.. for now
Stowe is offline   Reply With Quote Quick reply to this message
