Alcan/Deaver springs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-23-2006, 04:17 AM   #1 (permalink)
jsawduste's Avatar
Member # 77571
Going to do a spring under on my YJ.
Thought about the SOA; However combined with the tube fenders, crusher panels/flares and opened wheelwells. Plus a 1 inch BL to clear the NV4500 and the Atlas it is simply going to be to tall to run 35`s. Also the CG is going to be way higher then I want.
So I am looking at doing an approx 4" spring under using Alcan`s or Deavers combined with a set of Bilsteins on each corner. The springs will be custom made to match the weight of the YJ and all the add ons without being overly stiff.
Anyone offer an opinion on the spring brands ?
jsawduste is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 07:49 AM   #2 (permalink)
sand dune coon's Avatar
Member # 57123
do a soa with alcans and be done with it AND u can find all this info in the newbie jeep section, its been discussed many of times.
sand dune coon is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 08:42 AM   #3 (permalink)
Member # 15322
Be ready for some work! Those SUA's are a lot of work on them Wrangla's! Its real hard to get them springs under them axles. Just be sure to bolt up the springs and then slide the axles in from the side. Thats the easiest way!
2013 Jeep Grand Cherokee (Stock Daily Driver)
2002 TJ, 4.0/32RH/231/8.8/44 on 38" SX's
YJ4rocks is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 06:45 PM   #4 (permalink)
Member # 19876
I have been running Deavers for a number of years.(SUA) I really like them. Great ride on road and they flex real well offroad. I have Bilstein 5100 front and 5125 rear. IMO it rides like a TJ.
N24low is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 09:01 PM   #5 (permalink)
PIG
2indapink&1indastink
PIG's Avatar
Member # 4502
Deavers are great but for the cost you could have all the stuff to link you rig including shocks.
USE CODE: PIRATE10 FOR 10% SAVINGS ON YOUR NEXT ORDER!!!
COOL STUFF FOR YOUR BUGGY, JEEP, DODOGE 2500/3500
PIG is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 11:45 PM   #6 (permalink)
Member # 19652
Send a message via AIM to socalchef
Last I heard (when I asked Deaver), was they stopped doing custom stuff so much, unless the project caught the guys interest or the price was right. They had a couple production jobs and were keeping busy with that. If you're local, cruise by. Their barn is cool
socalchef is offline   Reply With Quote Quick reply to this message
